Old 09-03-14, 07:53 PM   #11
Rogue_Shadow
Default Re: Rear brake caliper sticking?
Just a quick post to say it's fixed
Took the caliper apart again and refitted the piston, everything looked ok. Yet the problem disappeared when reattaching it, maybe an uneven piston?
Either way that sorted out what was left of the binding problem.
The reason the rear wheel wasn't spinning freely, a dry chain with tight spots.
After lubricating the chain thoroughly & again once the chain was warm, the bike is sweet as a nut !
Obviously need to look at a new chain and sprocket set in the very near future.
Thanks for the help everyone, got there in the end
Old 10-03-14, 04:53 PM   #12
aesmith
Nice one. Ironically mine's started sticking now! I only noticed because the outer pad is worn much more than the inner, the brake's not binding at all and frees off perfectly. It's the sliding part that's sticking in my case, the piston moves quite freely and in fact I can see it retracting when the pedal's release. The sliding pins both feel perfectly free when the calliper's dismantled, but for some reason it doesn't work properly when assembled.
Rear brake issues paiste SV Talk, Tuning & Tweaking 5 19-09-10 12:21 AM
rear brake caliper devil1 Stuff Wanted 1 29-03-10 04:54 PM
Rear brake caliper pin twopots SV Talk, Tuning & Tweaking 14 22-12-08 06:48 PM
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
Rear brake caliper Viney Bikes - Talk & Issues 6 07-03-07 10:47 PM
