Old 17-10-04, 12:50 AM   #11
21QUEST
21QUEST's Avatar
Your pads/discs could be contaminated or glazed. get the pads out and go over lightly with a bit of wet and dry (dry) to get the glaze off and you might want to go over ever so lightly the discs with some very fine wire wool then clean them with some brake cleaner. Job done.
Ben
Nemo me impune lacessit.
Old 17-10-04, 10:27 AM   #12
Sincs
Originally Posted by Scoobs
Alternatively, remove the pads and smear a little copper grease on the back (the non friction side) This has worked for me in the past on both bicycle and motorbike disc brakes.
I'll second this. I used it on my brakes plenty of times over the years.
JUST DONT GET IT ON THE DISCS, otherwise you wont stop!
Old 17-10-04, 12:44 PM   #13
rictus01
rictus01's Avatar
What?
You mean the SV comes with a back Brake
Old 19-10-04, 12:09 PM   #14
iprideaux
Originally Posted by wheelnut
Mine does it since I put new pads in, I took them out and cleaned them again with brake cleaner, but it has come back after a couple of weeks. I think it needs the disc replacing too, but its a squeal, I can put up with
You did transfer the anti-squeel shims to the new pads, didn't you?
Old 19-10-04, 12:18 PM   #15
Grinch
I had this on my back and front brakes and I found cleaning up the pad with a bit of wet'n dry or rough brush, then little copper grease on the back sorts the problem out no end...
This was due to the bike sitting up for a while and developing a 'fluff' problem.
Old 19-10-04, 02:11 PM   #16
jambo
jambo's Avatar
Check the anti squeel plates (thin metal strips that go between the piton and the pad on the side closest to the front of the bike) are in. This will "toe in" the pads. Also lob copper slip on the back side of the pads. Should sort it
New squeal Stingo SV Talk, Tuning & Tweaking 3 21-03-09 06:57 AM
zx600r rear 'break' question, (rear brake). steve.s Bikes - Talk & Issues 6 19-02-09 07:50 PM
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
Brake light not working when rear brake is used.. StreetHawk SV Talk, Tuning & Tweaking 10 16-04-07 03:40 AM
Anti squeal plates ripped SV Talk, Tuning & Tweaking 2 22-02-07 08:54 AM
