#11 | |||||
Well we changed out the plugs with correct NGK's and it fired right up on jump start. Now the bike runs and starts every time. But I wonder if the coils are pulling too much for the stator to replenish? So far all we have done are short trips that involve a lot of idling, but I am worried about trips at speed where the charging voltage drops to a point where everything is driven by the battery. Again thanks to you all. |
#12 |
I doubt the type of plug would make a lot of difference to the current drawn by the coils, but someone can correct me if I'm wrong. The only real way, as all the other tests etc. seem to check out okay, is to get a fat ammeter to check the charging current. Some car shops sell them to retrofit to cars I think, could be worth a look. To be honest, I don't think you've got anything to worry about. If the headlight has been returned to stock (i.e. not pulling a ridiculous current, but these run fine with a pair of 60W bulbs anyway) and there aren't really any other things using the juice e.g. alarm, stereo, fag lighter, heated seat, demister fan, electric back window etc., then there should be no problem. The alternator should pump out enough current at any speed to run the bike, and there should be plenty of wallop at higher revs. Ride it and see, or get an ammeter, I think you've eliminated the rest of the stuff.
Something to remember, flattening a battery can kill it, though new ones are more resistant. I'm sure oyu knew that already. |
#13 |
Were you experiencing any problems with the guages flickering while riding?
I sure am but Im not sure how to check the voltage and resistance of the stator. Can you help me? The bike runs perfect but the guages turn off and on when riding but when the bike is at idle they work fine. I can be going a hundo down the interstated and the guages wont work but as soon as I pull the clutch in and coast with the motor idleing the guages come back on. A friend of mine had the same problem and said it was his stator, but I want to make sure first. Thanks, Damian |
Charging - AGAIN | Tris | SV Talk, Tuning & Tweaking | 7 | 15-04-08 04:15 PM |
charging system check - values | steveg | SV Talk, Tuning & Tweaking | 4 | 17-02-08 07:21 PM |
Over charging | Tris | SV Talk, Tuning & Tweaking | 8 | 21-02-06 12:13 PM |
So where did you fix your charging socket? | Mark_h | SV Talk, Tuning & Tweaking | 7 | 17-12-05 05:04 PM |
Charging System checking | philb | SV Talk, Tuning & Tweaking | 10 | 11-06-05 10:29 AM |
