Old 02-11-04, 08:47 AM   #11
Viney
Default Re: Guess that Noise?
Originally Posted by Ash999
Right, Need help!
Symptoms: Riding along and when i pull the throttle their seems to be a knocking sound which is on and off all the time when i pull the throttle. I checked the chain and it wasnt hot at all so i dont think its a chain tight spot. The rear disc is burning hot but i dont think its that, i think thats due to me braking hard and may have had my foot on it for a while cos my foots to low on the lever (it may need lowering) I dont know what it could be, because at a a stop it doesnt make any noise, with clutch in or neutral. I guess it could still be a chain problem (i.e. tight spot) or could be crakes which i doubt. Anyone else had similar symptoms?
How old is the chain? What you describe above is chain related. It sounds like the front sprocket is on its way out. What happens is, the sprocket teeth, instead of being pointy, beome claw shapped and the noise is the chain releasing itself over the 'claw'. Now, i have been advised that to get the best life out of a chain, is to fit a scotoiler(i can recomend it) and also fit a Suzuki OE front sprocket, as apprently they are much tougher than any pattern part.
So i would start with the chain and sprockets.
As for the rear brake issue, could be that the caliper needs serviceing as it sounds like the pistons are binding.
HTH
Guess who ? newts924 Idle Banter 20 12-09-08 01:08 PM
Guess who's NOT going to the AR? Lozzo Bikes - Talk & Issues 20 05-07-08 09:55 PM
Guess the ****... sarah South & West Surfers 47 29-09-07 12:48 PM
You'll never guess what!!?!?!?! _Stretchie_ Idle Banter 5 14-02-07 05:38 PM
Screeching noise? what noise does your SV make? branny SV Talk, Tuning & Tweaking 5 30-06-06 12:09 PM
