Old 03-12-04, 01:20 PM   #11
rictus01
rictus01's Avatar
Originally Posted by bikageboy
easy peasy. i got 2 hours free today - can i fit new brake pads ?
what you doing for the other 1 hour 55 minutes
Old 03-12-04, 01:28 PM   #12
Warren
probably trying to figure out why its not working
Old 03-12-04, 01:29 PM   #13
BaggaZee
One thing to remember in this weather is to make sure that the screen isn't too cold before you start, seriously
With mine the screen needed a little bit of persuasion, just a small flex, to get it in properly, the first time I did it it was freezing and the screen cracked
Got it replaced, warmed the new one over a radiator and it flexed and fitted no problem.
Old 03-12-04, 03:13 PM   #14
Scoobs
Done it!!!!
All done and dusted 15 minutes tops!
Easy Peesy.
Bikeage Boy. Brake pads! No sweat providing retaining pins ain't seized bloody solid
Old 03-12-04, 03:14 PM   #15
Scoobs
*TIP*
Push the pistons right back into the calipers before you take the old pads out.
Old 03-12-04, 03:24 PM   #16
Warren
Originally Posted by Scoobs
Done it!!!!
Easy Peesy.
whats a retaining pin ?
all sorted - got a bleeding hand now from pushing the pistons back into the caliper
Old 03-12-04, 03:26 PM   #17
Scoobs
Done it!!!!
Easy Peesy.
Oops!
Tip should have read push pistons back into the caliper without giving yourself a bleeding hand
Old 03-12-04, 03:33 PM   #18
Warren
so heres a question for you
whats the meaning of the following terms
seized caliper
loctite (and what does it do)
copper grease
Old 03-12-04, 03:45 PM   #19
Viney
seized caliper - Pistons dont move in and out as supposed to
loctite (and what does it do) - Its a goo that locks threads of bots to stop them undoing by thierself
copper grease - Exactly what it says on the tin. A greese that is loaded with copper. Stops break squesl when applied to the rear of the pads, and also is an anti siezing compund when applied to anything you want to remove...bolts, pins etc.
Old 03-12-04, 05:00 PM   #20
Warren
i always thought that the sqealing noise came from the pads rubbing on the discs.
so how exactly does copper grease stop the noise ?
50 free Hours with AOL Richie Idle Banter 6 01-11-08 08:59 AM
These will keep you amused for hours :) Blue_SV650S Idle Banter 0 14-05-08 04:59 PM
4 hours Dicky Ticker The Essex Lounge 3 06-09-06 11:30 AM
Off to France in 24 hours..... 454697819 Bikes - Talk & Issues 7 13-05-06 09:43 AM
Two hours to go... markfc SV Talk, Tuning & Tweaking 5 04-03-05 02:15 PM
