Old 26-01-05, 12:12 PM   #11
Carsick
Ahh, well, then lucky for me, first time I filled it was new, second time it had run out
Old 26-01-05, 12:13 PM   #12
Amanda M
Originally Posted by Viney
You only have to go through the airfilter thing wehn purging the system (When it runs out of oil completely )
How many times have I done that?!
Old 26-01-05, 12:41 PM   #13
Shinsei Jutsu
I guess 5. am I right? am I? (I'll get back to idle banter)
Old 26-01-05, 01:09 PM   #14
Amanda M
Probably about right actually. I learned my lesson eventually
Old 26-01-05, 05:21 PM   #15
Anonymous
How does one prime the system? Lets assume one has a dry, unused Scottoiler - obviously if you just fill the tank up with oil it's going to take a long time before it bleeds through the pipe to the chain assuming the chain oil has a standard viscosity!
Old 26-01-05, 06:00 PM   #16
Carsick
to prime it, start the engine then put pressure into the reservoir by doing what I suggested doing to fill it up.
Old 27-01-05, 10:16 AM   #17
BaggaZee
Turning the flow rate up to max first, or you'll be there all day!
Old 27-01-05, 01:17 PM   #18
No need to start the engine, just turn the adjuster to "Prime", and to make it easier still, connect the rubber filler plug to the bottle, not through the filter as some have suggested, and pressurise the reservoir that way.
How long it takes to fill depends on how long the delivery tube is, and the route taken.
Unless there is still a significant amount of oil in the delivery tube, when the reservoir is empty, the tube won't refill on it's own, the oil is drawn through the system by the weight of the oil in the tube, no oil = no weight = no working.
Scottoiler gavinsky23 Stuff Wanted 1 19-05-08 08:27 PM
Scottoiler Stevetmanchester Stuff Wanted 5 17-05-08 08:33 PM
Scottoiler gavinsky23 For Sale - SV's and SV related items 2 17-05-08 07:27 AM
scottoiler done. nothing to see here hovis South & West Surfers 26 25-01-07 12:18 PM
DIY Scottoiler Diveboy Bikes - Talk & Issues 1 11-03-06 08:51 PM
