Old 29-03-05, 10:53 PM   #11
Noise reduction, apparently. It's an absolute b**tard to get out, by the way, if you're thinking of it. It definately gave a benefit when i had the Renegade filter in but I couldn't say if it does for the BMC, never had it on with that filter.
BTW, once I'm back on the bike I'll be getting various dyno runs done, to comapre the RS with a desnorkelled stock filter among other things... So if you're OK to wait I can hopefully give you conclusive figures (won't be tuning for peak power for both, just a/f charts to compare.)
Old 29-03-05, 11:07 PM   #12
InvisableGeek
ok thats cool, again it's a race bike so i'll do it even if it adds the smallest amount of power
Old 30-03-05, 02:28 AM   #13
xaun
I'm not sure if I'm thinking of the same "foam" you are. Mine was actually quite easy to remove. It just had some metal tabs that I had to bend and slip the foam off of. Perhaps someone could show me a picture so I'm sure.
Old 30-03-05, 05:42 PM   #14
Hum, don't know what that is... What I'm talking about's just a thin high-density foam glued to the underside of the tank, directly over (and behind) the filter on the carbed bikes. It could be it's a territorial noise thing, mind.
Old 30-03-05, 05:48 PM   #15
xaun
Maybe Suzuki realised how much of a pain it was to remove, so they mounted it differently. I was wondering if it was a heat displacer so the fuel didn't do something irraddic.
Old 30-03-05, 05:55 PM   #16
Well, I've had it removed for about 4000 miles and I'm still not dead, if that's any help
Old 30-03-05, 05:58 PM   #17
xaun
It certainly is. And that brings up my next question. How much ambient heat would it take to combust gasoline? If it was just radiant energy.
Old 30-03-05, 06:07 PM   #18
MARK IN SC
it will boil first.. you need a spark and/or compression to ignite gasoline vapors. My foam has been gone for 10K+? miles... shes just peachy.
Old 30-03-05, 06:08 PM   #19
xaun
Cool, man, it's a good thing I have geniuses like you on tap 24/7.
Old 30-03-05, 11:41 PM   #20
GDBD59
FWIW........my SK1's tank was replaced under warranty last year & didn't come with any foam on the underside.......????
Hole in intake rubber? cammy SV Talk, Tuning & Tweaking 19 16-04-09 10:11 PM
Air intake question John 675 SV Talk, Tuning & Tweaking 9 08-01-08 12:20 AM
Curvey intake valves and some collets svrash Stuff Wanted 2 30-01-07 09:48 PM
intake cams SV650 K3> r4ce_e3nd Stuff Wanted 3 29-05-06 10:08 PM
Curvy intake cams, engine barrels northwind For Sale - SV's and SV related items 0 17-01-06 02:19 PM
