Cleaned up my secondhand engine and put it on the bench ready for the rebuild and i noticed a hole in the rear rubber tube the carbs go onto. Does a vacuum hose go into it or has it been bored for a scotoiler vacumm hose feed. thanks Cammy
Sorry sv650 1999
Vacuum hose, should have a brass spigot on it.
There is no carbs mounted on the engine yet still to get them just the rubber mounts on engine if this helps
Vacuum for the fuel tap comes from the rear carb. Vacuum for the fuel pump comes from the hole ... it should be on the right hand side of the rear rubber IIRC.
A tube pushes onto a brass spigot. If it's just a hole then they've probbly yanked the hose and spigot out. as one bit.
And its on the rear boot none on front the boot
Thanks spot on looked on parts drawings but did not see anything so thats why i asked thanks again hope u can buy one
#9 |
Just take the intake boot off tother motor when you swap it...
#10 |
Dont have another engine building from scratch i have got a real challenge the site will be fed up with my questions
WANTED: SV1000 Snorkel / Intake pipe | The Guru | Stuff Wanted | 3 | 19-05-09 07:47 AM |
Air intake question | John 675 | SV Talk, Tuning & Tweaking | 9 | 08-01-08 12:20 AM |
Curvey intake valves and some collets | svrash | Stuff Wanted | 2 | 30-01-07 09:48 PM |
intake cams SV650 K3> | r4ce_e3nd | Stuff Wanted | 3 | 29-05-06 10:08 PM |
Air Intake! | InvisableGeek | SV Talk, Tuning & Tweaking | 25 | 31-03-05 06:35 PM |
