#11 | |
#12 | |
#13 | |
![]() ![]() Your's doesn't look too bad either ![]() Just curious, what's included with the bearing Zoran sells ? and how does it differ from the original ? |
#14 |
Looks good Northy, bit of a surprise
![]() Deffo a "here's one I made earlier moment"..... $60- for the bearing is interesting, why not just swop the stem? Will the SV stem press fit into the SRAD bottom yoke? I reckon master cylinder of a TLR is what you'd want, unless you can find a radial Brembo.... ![]() What's next? ZX6-R swingarm with 5.5 inch rear wheel? Trans warp drive? |
#15 |
What can I say but
![]() ![]() Burner , it's probably cheaper to just buy the bearing. A stem swap would cost you a minimum of £50 The good thing about the stem swap is I can swap between the SV and GSXR quite easily. Recently I've run GSXR1000K2 , 750K2 , 600K2 forks. Northy you might want to have a look at the fireblade(2000-2001) bars(pretty sure they are 50mm). They are a bit higher than the Gixer ones but don't know how long they are. Good work Dude. Cheers Ben |
#16 |
Surely with higher bars you'll need to get the nekkid models control cables?
I'd really love to do a USD front end swop but without a garage it just makes my bike too stealable. When I had my streetfighter the local chavs kept peeling back the cover to check the front end, I had RWU forks. |
#17 |
Very Very Nice
#18 |
Thanks folks
![]() Could swap the stem but without a press it'd still cost- also I believe you'd need to build or have built a spacer for the top yoke as well. The bearing's a roller type rather than ball, if that makes any difference. Also, buying it keeps Zoran sweet when you've spent 3 months asking him stupid questions ![]() Burner, the GSXR bars end up lower than the SVs were so I reckon I could go up around an inch without changing any cables- the front brake lines are now over-long and look a bit daft... As it is the riding position's slightly more aggressive, which is fine, but the bars are also slightly narrower which made fitting up the controls a wee bit tricky. Also, the cable clearance betwen fairing and bars isn't too good, my RHS heated grip cable is giving me gyp. Thanks for the tip on the Blade ones Ben, apparently Vortex do high bars for the GSXRs too. Not put much thought into it yet TBH. What's next? First, finish up the front end ![]()
I'm bored. | Stig | Idle Banter | 14 | 30-01-08 02:56 PM |
God i am Bored ! | amarko5 | Pennine Massive | 12 | 27-08-07 10:21 PM |
Bored? try these. | neio79 | Idle Banter | 3 | 01-06-07 07:06 PM |
Not much to do this weekend?? Bored?.... | Daimo | Idle Banter | 1 | 24-08-06 11:06 AM |
I'm bored... | Shinsei Jutsu | Idle Banter | 10 | 18-05-06 06:35 PM |
