Old 10-09-05, 11:56 PM   #11
21QUEST
21QUEST's Avatar
When it gets fooked by someone I guess
Ben
Nemo me impune lacessit.
Old 11-09-05, 12:08 AM   #12
TSM
The Sick Man
TSM's Avatar
Originally Posted by PeterM
Might want to try WD-40/RP7 or whatever you guys have for loosening threads before drilling away. The air screws shouldn't be that hard to move, unless someone has set them at the std 2 1/2 turns out and used threadlock (completely unnecessary).
Yes, 137.5 Mikuni mains are std from the factory too.
Tried WD4-, even left it for a while. Did not work, they seem set solid.
What about thoes bits to remove broken bolts? Will they work?
If i try to drill it out then i am guessing that it will have to be something like a 4mm bit then use a 5mm tap to take the old stuff out and put it back to normal (dont know what the sizes are)??
Old 11-09-05, 12:17 AM   #13
PeterM
Last resort should be drilling. Try to give the end of your scredriver a good knock with a hammer to try and free the thread up a bit. (Place screwdriver on head of screw and hit along axis of driver & screw like hammering a nail in) Sometimes this will free the thread.
If you do have to get a tap, get the smallest you can find, it's not a terribly big screw.
Old 11-09-05, 12:24 AM   #14
TSM
The Sick Man
TSM's Avatar
Tried that as well.
Old 11-09-05, 12:26 AM   #15
21QUEST
21QUEST's Avatar
I take it the head is wrecked. Drill bit wise 4mm is too big to off with. You wan't to start with the really ickle ones 1mm/1.5 and go from there.
You'll need a new screw and the o ring. Have you got those already. Shoot me a PM(with phone number) as I may be going to Dulwich tomorrow.
That being the case provided you need to get your bike on the ASAP I'll get you a carb and you can nick an air screw off it. I'll of course be need you to post a replacement to me..
Ben
****ing suzuki ****ty screws davepreston SV Talk, Tuning & Tweaking 38 26-01-09 09:20 AM
Tight screws FG1 Idle Banter 12 18-01-09 11:33 AM
The screws. Stig Photos 19 12-01-08 12:22 AM
Bar End Weight Screws Banus SV Talk, Tuning & Tweaking 9 03-05-07 03:09 PM
tap and die set (AND SCREWS) Warren SV Talk, Tuning & Tweaking 15 06-07-06 08:56 PM
