#11 |
did you remember to pull in the clutch?
![]() ![]() I bought a Datatool charger for £39 and found out it was senile dementure :P |
#12 |
Looks like it's the battery that is goosed. It wouldn't take a charge and when I rigged up a side light bulb to it, not a glimmer.
Weird, as I said before when you put a volt meter over it you get 12.5V then when you hook up the bulb....absolutly nothing! I've never had a battery die on me like that before, it was just like switching off a light. |
#13 |
A healty 12V battery would actually give you 13.5V or more on a multimeter without load. 12V showing up on a multimeter shows it needs a charge. CHARGE IT!
#14 | |
#15 |
make sure you have the battery is toped up to its max with distilled water then charge it over night and try again if it stil dont work umm get a new one i guess.
#16 | |
#17 |
Put a new battery on it....everthing's cool. Very strange.
#18 |
Hey all,
If the battery can't even light a lamp the it's had it's chip. As someone said, just because you have voltage it doesn't mean you have amp's. This is phantom voltage, a meter will tell you that you have voltage but as soon as you have load on the circuit it will disappear. ![]() God the superbikes were good. ![]() |
Dead 02 SVS | 2whelltraveler | SV Talk, Tuning & Tweaking | 4 | 12-05-09 01:25 AM |
It's dead. | Red ones | SV Talk, Tuning & Tweaking | 10 | 26-01-09 10:09 AM |
dead sv | hlaf_lyfe | Bikes - Talk & Issues | 15 | 26-01-08 09:52 PM |
Dead Can? | M65 | SV Talk, Tuning & Tweaking | 19 | 09-05-06 12:12 PM |
Not quite dead... but definitely ill | andyaikido | SV Talk, Tuning & Tweaking | 0 | 25-02-06 04:31 PM |
