#11 | |
I keep hearing horror stories of Suzuki bolts being made of cheese. Whenever I get the opportunity I replace any I remove with Stainless Socket headed bolts. However, I have never felt the need to change the oil drain plug. I have to question why I read of drain plug problems. They should never be torqued that tight as to make removal a problem. Perhaps investment in a set of decent flank drive sockets should be a pre requisite for any home mechanic.
Not Grumpy, opinionated. |
#12 | |
Don't use a spanner with stud extractors, you are asking for it to snap, use a tap wrench, that is why the have a square head
#13 | |
Cheers Mark.
#14 |
Just rember that its an allot sump and can crack if you hit it, and its not a seperate part from the engine
Sump plug washer - where from? | pencil shavings | SV Talk, Tuning & Tweaking | 26 | 17-03-09 08:52 PM |
Sump plug bolt | Jimbo_Bimbo | SV Talk, Tuning & Tweaking | 28 | 04-09-08 12:42 AM |
Sump Plug Torque? | skov | SV Talk, Tuning & Tweaking | 2 | 27-02-08 08:38 PM |
Sump plug washer | yorkie_chris | SV Talk, Tuning & Tweaking | 3 | 29-09-07 10:44 AM |
Pants! Sump plug... | localhost | Bikes - Talk & Issues | 12 | 20-01-06 11:27 AM |
