Old 07-06-06, 10:24 PM   #11
Biker Biggles
Biker Biggles's Avatar
You did'nt re connect the live feed after fitting the fan,thus no charge to the battery.
Old 07-06-06, 10:26 PM   #12
svrash
very close
Old 07-06-06, 10:29 PM   #13
Xerbraski
Had the terminals reversed on your battery?... though that'd probably make it exlpode.
Old 07-06-06, 10:29 PM   #14
21QUEST
21QUEST's Avatar
The rectifier was not plugged back into the harness.
Ben
Nemo me impune lacessit.
Old 07-06-06, 10:36 PM   #15
svrash
Ben
I completly forgot to plug the reg/rec back in
Old 07-06-06, 11:56 PM   #16
instigator
On a seperate note, are you small? Because bump starting an sv on a flat is fairly easy. (unless this can't be done without your reg/rec plugged in)
Old 08-06-06, 12:16 AM   #17
thepyrofish
I couldn't bump start mine when the battery died
Old 08-06-06, 08:05 AM   #18
Stormspiel
I've bumped mine loads of times, Find it fires best when in third and thumbing the starter. First gear just locks the rear, second you have to get it going pretty quick. Just get it going to about 15Mph, Hop on, Flick ignition on, Knock into 3rd, Bounce the suspension while dumping the clutch and thumbing starter ( bouncing puts more pressure on rear tyre so it'll grip) and bang she goes.....That how i do mine anyways .
Old 08-06-06, 08:07 AM   #19
branny
HEY!!!
Im a pretty big guy and i couldnt get mine bump started on a flat battery without a push off a couple of guys!!!
Old 08-06-06, 08:29 AM   #20
svrash
I've never been able to bump mine.....will try this way next time....but then i'm too lazy to run along with a bike that weighs more then me (i'm 8 1/2 stone )
Optimate battery charger drains the battery flymo Bikes - Talk & Issues 10 10-06-09 10:41 AM
170 miles on a full tank & thats your lot im an idoit hovis Bikes - Talk & Issues 57 25-06-07 02:29 PM
Streetfighter - How many different bikes can you spot? Cloggsy Bikes - Talk & Issues 12 20-03-07 12:33 AM
Spot my dot? Daz TOTALSV Ireland 0 21-06-05 11:20 PM
Battery/Starting problem - new battery hasnt fixed it! Aaron SV Talk, Tuning & Tweaking 13 24-01-05 05:21 PM
