Old 21-06-06, 01:49 PM   #11
Jase22
Yup nekkid only has one, yet another benefit of having a faired one!!
Old 21-06-06, 02:38 PM   #12
Blue_SV650S
If it has MPH on the clockface (not an overlay) the odometer will be in miles too.
Old 21-06-06, 03:19 PM   #13
Stu
Trinity
Stu's Avatar
Originally Posted by Jase22
There are also 2 different fuel lights just so you're aware.
The light starts to flash when you're getting low on fuel, ie into reserve, then when it stays on constantly you need to be refilling within about 10 miles. I don't tend to push it this far into the reserve, flashing light usually indicates me to fill up.
Is that the right way round? because mine stays constant first and I was relying on it flashing before I had a problem - never seen it flashing yet even 50 miles after it first came on!
Old 21-06-06, 03:32 PM   #14
Blue_SV650S
The curvy is indeed flash (annoying as hell!! ) then soild light, don't know about the pointy?
Old 21-06-06, 04:21 PM   #15
fizzwheel
fizzwheel's Avatar
Depends which pointy. I think the K3 & K$ pointies work differently the K5's
Old 21-06-06, 04:33 PM   #16
Viney
You can if youa re careful get 200 miles out of an SV thank, 40 miles on the flashing light and another 37 on solid, this however leads to the fact that if you corner to the right, your bike cuts out as it only has 300ml of fuel left!!
Old 21-06-06, 04:37 PM   #17
Grinch
I've only managed 187 when it died...
Old 24-06-06, 07:05 PM   #18
Yarodia
Viney and Grinch, your living on the edge! I wussed out at 175miles and filled up pronto.
I used to get about 145miles to a tank before I got the fuelling sorted at the Dyno Station, get loads more miles now and a smoother ride. The fuel I save will probably pay for the Dyno set up
MOT what do I need... A few questions ? Richie Pennine Massive 28 10-12-07 09:19 PM
ABS questions. Mossy Bikes - Talk & Issues 36 23-08-07 07:49 AM
Questions questions...(funny noise,luggage, ferry) the_lone_wolf SV Talk, Tuning & Tweaking 23 23-05-07 07:19 PM
a few questions....well 5 questions....from a newb flynn209 SV Talk, Tuning & Tweaking 12 10-07-06 10:56 PM
Blond questions about a blond SV (k1) Bad Intentionz Idle Banter 5 07-01-70 06:34 PM
