#11 | ||
#12 | |
However, please feel free to test this on your chain and tell us whether your chain doesnt last as long using WD-40 as opposed to lubricants which are designed not to dissolve the rings. ![]() ![]() |
#13 |
WD40 won't dissolve chain 'O' rings, the solvents aren't that strong and they won't be there long anyway as they are light and evaporate quickly.
WD40 is a lubricant and will lube your chain just fine. However, as it is such light lubricant, it will do the job for a very short time, so short a time as to make it an impractical choice at the very least.
#14 |
o new thought......
could i spray soem WD in me scottoiler n itl clean me chain and then put some oil back in ??? just a thought about how to clean me chain the lazy way ? ![]() ![]() |
#15 |
If you have a Scottoiler the there's no need to clean the chain. Just turn the wick up for a few miles
#16 | |
#17 |
I used to love WD-40 but recently bought a can of GT-85, it smells lovely.
#18 | |
#19 |
If you want to clean your chain use the brake and chain cleaner..and then proper lube to lube it.
If you spray WD40 on a rubber o-ring it will swell and deteriate after time. Not good to constant use on your chain. |
#20 |
Chain o-rings (along with most I guess) are made from nitrile rubber, which is resistant to degradation from oil, etc. Paraffin/kerosene shouldn't harm chain o-rings, as it's just another fraction of raw crude but from further up the column.
The WD-40 manufacturer won't tell you what's in it 'cos it's a secret. ![]() |
