Old 22-09-06, 08:20 PM   #11
21QUEST
21QUEST's Avatar
Originally Posted by weazelz
does anyone know the length of standard springs & spacers?
Standard springs are 315mm and spacer is 198mm(non-adjustable preload forks) .
You can cut down the existing especially if never going to be put back to satndard or use PVC. The OE spacer are probably not that expensive. I believe I have some PVC knocking about.
Ben
Edit: Spacers are only about a fiver. I'll go with cutting down originals myself.
Nemo me impune lacessit.
Old 22-09-06, 08:51 PM   #12
weazelz
great, thanks. cutting down the originals is what I was planing to do, I just wanted to make sure there'd be enough pipe to do so, given that I want to run the progressives without the adjuster caps which would make those spacers 15+mm short
Old 22-09-06, 09:11 PM   #13
21QUEST
21QUEST's Avatar
If I'me thinking right that would make it
450mm(progressive springs) minus 315mm(OE springs)= 135mm(difference in spring lengths)
Meaning the spacers have to be cut down 135mm giving you 63mm(198-135mm). The spacer you already have should work 'as is'. Don't know how much static sag(bike) Hyperpro should have but my calculation is saying a 3mm difference bearing in mind Hyperpros are normally just straight swaps.
Hmm...IIRC, did you happen to get the springs from JHS/wondering if they were supposed to be a straight swap jobby?
My calculations should be right and in that case the cut down spacer you have should suffice you could cut down 3mm off if feeling fussy
Ben
Old 22-09-06, 10:02 PM   #14
weazelz
sorry, what I meant was...
I can cut ~20mm off the 198mm spacers to work with the linear springs & adjustable preload caps; I can then cut another ~14mm off the spacer to put in the racetech. I want to compare the linears without/with the racetechs, otherwise I'd do it in one go. this is all fine
however, not knowing (then) the length of the original springs & spacers, I didn't know whether the original spacer would be long enough to use with the progressive springs & non-adjustable preload caps - 60mm spacer & ~20mm to replace teh preload adjuster - so 80mm. since you say the standard spacers are 198mm, which is >80mm, so all is fine
btw - the progressives & adjustable caps came from JHS with the 60mm spacer as a set
hope that is clear this time
Old 22-09-06, 10:17 PM   #15
I reckon I've got a pair of standard spacers somewhere on the garage floor...
Old 24-09-06, 07:48 AM   #16
Blue_SV650S
Remember it is the 'sag' you are setting, the heavier springs will require less preload for the same sag ... so its not like you can directly do the sums like that, but these numbers will give you a ballpark.
p.s. I'd be very intrested in the resuts of the with-without emulators test
Old 24-09-06, 04:15 PM   #17
weazelz
yup, noted. I have adjustable preload caps so it's less of a big deal, but I'll set the sag properly
me too. it'll be a one-time deal though, once the damper rods are drilled out there's no going back (except with new damper rods
Old 24-09-06, 04:25 PM   #18
Blue_SV650S
An interesting experiment, that I might use the results with on my road bike, but once done, I can’t see any reason you would want to revert back anyway. I am happy with my setup, which will be exactly the same as you have, sure if you spent more time and money you might be able to come up with something better, but I feel I can do pretty rude stuff with what I have already!! so fine for trackdaying
How much were the emulators? They are about £125 aren’t they?
Old 24-09-06, 04:48 PM   #19
weazelz
I was just meaning that once it was done ti wouldn't be a 10 minute job to swap it back if someone else wanted to see the difference with/without
I think (hope) that once the emulators are in there then the suspension should be pretty much optimum. if I was looking for anything more I'd probably buy a cbr6 or similar, something with semi-quality suspension to start with.
£115 from pdq: http://www.pdq1.co.uk/racetech.htm
Old 24-09-06, 05:14 PM   #20
Blue_SV650S
A Gixer front end conversion on ya SV would probably be a cheaper option
Like I said I am happy with the confidence my ‘front end’ gives me for trackday purposes, a revelation over stock!!!
Racetech Emulators for 99 - 02 curvy (brand new) charlie13 For Sale - SV's and SV related items 15 13-03-09 05:50 PM
Racetech emulators - what fork oil? skov SV Talk, Tuning & Tweaking 0 27-05-08 10:36 AM
Racetech emulators natcar SV Talk, Tuning & Tweaking 58 31-10-07 12:36 PM
Racetech emulators ajbuchardt SV Talk, Tuning & Tweaking 1 12-08-05 05:32 PM
Racetech Emulators and springs pjsv650s Ancillaries 3 30-07-05 12:58 AM
