Old 06-10-06, 09:18 PM   #11
weazelz
Originally Posted by wyrdness
Originally Posted by weazelz
I mis-read that as rotary for a minute (not wankel rotary) - riding along with those cylinders spinning between your knees would be hair-raising
the torque reaction on the longitudinally-mounted one must be intersting too!
The engine doesn't rotate - just the crankshaft. See here:
http://science.howstuffworks.com/radial-engine2.htm
yes, I know, but a rotary one does
I never understood how those rotating aircraft ones worked.
http://en.wikipedia.org/wiki/Rotary_engine
"...instead of having an orthodox fixed cylinder block with rotating crankshaft, the crankshaft remains stationary and the entire cylinder block rotates around it"
Old 07-10-06, 12:51 PM   #12
shao
http://www.keveney.com/Engines.html
Probably been posted somewhere on here before, but definitely worth a look if you havent seen them, the engine weazelz refers to would be a Gnome Rotary (by their naming conventions at least, there's definitely room for interpretation, i tend to assume wankel if someone referrs to rotary engines, as in RX7/8) Anyway, good set of animations, and very helpful for figuring out how the heck some of these engines actually work.
Radial Master Cylinder? squirrel_hunter Bikes - Talk & Issues 4 28-07-07 10:17 PM
Radial Calipers £100 Stu For Sale - SV's and SV related items 5 06-11-06 11:03 AM
Radial Brakes Banus SV Talk, Tuning & Tweaking 6 30-04-05 08:16 AM
Swap GSXR forks/radial brakes/radial master cylinder/wheel Teknic SV Talk, Tuning & Tweaking 2 16-03-05 07:19 AM
Explain radial brakes to me, please Anonymous Bikes - Talk & Issues 4 12-02-05 01:26 AM
