#11 |
I'll go take some pics
#12 | |
#13 |
Nope haven't tried threading it in cause i'm afraid of the aftermath
![]() thinking i won't be able to go back to standard |
#14 |
Knob faced knobster
the length shouldn't be a problem but you really dont want to cross thread your m/c or calipers!
2011 Speed Triple 1050 |
#15 | |
Knob faced knobster
give it a try, if you cant trhread it in by hand its the wrong thread pitch
#16 |
yeap that's what i was thinking about crossthreading
nope can't do it by hand defo wrong pitch |
#17 |
if your threading it in with just your fingers then you'll be able to tell if it's cross threaded or the wrong pitch....
... I don't think that they've changed cylinders from the k3 to the k6 - it is a budget bike so why change something that is almost good enough? |
#18 |
Knob faced knobster
are you going forthe same set up as before or the 2 line set up?
If it's the 2 line and the double length banjo doesn't fit then it's definitely the wrong one if ypou're going for the 3 line set up then compare all the bolts you've got as i said earlier the m/c and the calipers have different thread pitches.
#19 |
I'm going for the 2 line setup at front and as u say the double length banjo doesn't fit (thread pitch wise)
#20 |
Tell HEL that they've sent you the wrong double banjo - mine fitted without any prob!
SV Racing Parts, GSXR Brake Caliper Adapter Brackets, & Galfer SS Brake Lines & Pads | sv-racing-parts | SV Talk, Tuning & Tweaking | 42 | 15-09-11 10:27 PM |
brake lines. | x Silver x | SV Talk, Tuning & Tweaking | 10 | 03-01-09 09:11 PM |
HEL Brake Lines | buckstone | SV Talk, Tuning & Tweaking | 1 | 20-05-08 04:24 AM |
Servicing my brakes and fitting braided lines | Grinch | SV Talk, Tuning & Tweaking | 20 | 09-02-07 02:06 PM |
HEL brake lines | streetos | SV Talk, Tuning & Tweaking | 4 | 31-03-05 09:51 PM |
