Old 12-12-06, 04:24 PM   #11
jambo
jambo's Avatar
With a lot of bikes a "clicking" or "clunking" noise from the front end when transferring weight or hitting bumps can be an indication that the head races are loose. The SV is no exception. However, as others have pointed out the standard forks do clunk a bit. Stiffer springs / fork oil, I believe lessens this but I wouldn't get too hung up on it.
As an Aside "Triple clamp" is US-speak for Top & bottom yokes
Old 12-12-06, 04:31 PM   #12
Sudoxe
Yep, standard SV forks bottoming out.
Dan
Old 12-12-06, 05:05 PM   #13
BILLY
Mine still clunks with the SRAD750 front end!!
Old 12-12-06, 05:13 PM   #14
r4ce_e3nd
mine doesn't with emulators, other springs and oil.
Old 12-12-06, 05:14 PM   #15
I'm suer further down that thread I called that guy an idiot There's loads of reasons a bike's front end can clunk, assuming it's head bearings is just plain stupid, and telling people that they have to tighjten their head bearings is completely irresponsible. It might be head bearings, aye. Remind me next time I see you and I'll check it
But there's loads of things that can cause a clunk, the SV has a habit of clunking. I think RandyO blames the gauge cluster, but he has a naked. Mine was something internal in the forks, though I have no idea what. It stopped completely when I changed the oil for 15W. Or it could be your brake pads. It could even be the calipers having a rattle, or loose/worn brake discs, or some other loose part just about anywhere up front.
Old 12-12-06, 05:24 PM   #16
chazzyb
Originally Posted by TSM
Originally Posted by chazzyb
Whatever you do, don't adjust your head bearings as described: it's ********.
Not totaly, head bearings do click when loose under braking, but its unlikley to be that on standard SV's as most people know the cluck is actualy from the fork internals and they all do that. Now if it only happened under quick/heavy braking then i would look at the bearings.
I agree. The point I'm making is that you do not adjust head bearings as described!
Old 12-12-06, 06:59 PM   #17
Having said that, in Duck-Man's case it's most likely caused by an essential bit having gone missing
Old 12-12-06, 08:49 PM   #18
riktherider
the fork inernals in the sv's are dirt cheap. they "clunk" becasue of the dampening system on the sv's. there are only two holes (i think i remember rightly) lsat time i took the forks apart, and i spoke to the guy at cresent, and the sound is basicly the rods bottoming out on the bottom of the forks. where the oil cannot be dispersed through the dampening holes quickly enough and thus creates the forks bottoming out. you get it a lot on cheap montian bike forks.
if you strip a decent pair of mountian bike forks, like marzocchis or rock shocks, you would see that the damper rods have multiple holes in. my old marzochhi forks had about 12 holes per damping rod as bicycle forks under do more movement in general, they need to disperse more fluid faster, so they have more holes.
I was thinking of drilling extra holes in the damper rods so i will post the results when the bike s back on the road.
Old 12-12-06, 10:47 PM   #19
Well, if you drill extra holes you're going to massively effect the damping rates... You don't really want that, SV forks are underdamped as standard. You'd probably end up having to add heavier oil to counter it, which would defeat the purpose. Mountain bike forks are doing a completely different job, you can't really compare a 170 kilo bike with a 10 kilo one, or the forces from hitting a pothole at 100 with landing a big jump at 20mph.
Mountain bike forks are still incredibly basic- but they have an easier job since compression modulation is the key, rebound's much less important. SV forks need to balance the two. Really all damper rod forks are a compromise.
Old 13-12-06, 08:30 AM   #20
Duck-man
HAHAHA! It was only the one thing missing!
Knocking over bumps AndyBrad SV Talk, Tuning & Tweaking 12 02-09-08 01:56 PM
help needed, clunking sound and shuddered! ScottishRawker SV Talk, Tuning & Tweaking 15 29-06-08 08:44 AM
Ladies Bike gear - Small or Extra Small! StreetHawk Stuff Wanted 8 07-12-07 06:18 PM
Would You Like More Bumps With That Sir? RhythmJunkie Idle Banter 15 25-07-07 07:02 AM
Small windscreen for curvy naked SV 650 The Butler SV Talk, Tuning & Tweaking 9 16-03-06 03:29 PM
