Old 06-05-08, 02:31 PM   #1
ScottishRawker
ScottishRawker's Avatar
Default help needed, clunking sound and shuddered!
Hey people,
was comming home from town after picking up the missus and just before i got home when i pulled in the clutch at low revs to stop it sort of shuddered and made some clunking sounds.
its a k5 pointy, with a good amount of oil.
i checked in the drive there that if i make it move then rev it to about 2.5k revs then it makes the noise.
so what could it be?? help please?
Adam
ScottishRawker is offline   Reply With Quote
Old 06-05-08, 02:34 PM   #2
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
Default Re: help needed, clunking sound and shuddered!
did you have your foot resting on the gear pedal? if it was in 2nd or neutral and you accidently brushed it into first it'll make that noise and shudder a bit...
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 06-05-08, 02:47 PM   #3
ScottishRawker
yeah i know that can happen,
but nope that wasnt it as when i tried it in my drive i had both my feet on the ground :S
Old 06-05-08, 02:49 PM   #4
Alpinestarhero
Low tick-over?
Did you pull the clutch in just before it stalled? where you rolling along on tickover?
Matt
Old 06-05-08, 03:16 PM   #5
ScottishRawker
my tickover is 1.5k and it shudders at 2k
Old 06-05-08, 03:18 PM   #6
Alpinestarhero
ah, not good...should be relativly smooth at 2k....
have you checked the chain tension and everything?
Matt
Old 06-05-08, 03:19 PM   #7
sv_rider1990
Chain may need tightening or replacing mine made a knocking and shuddered the chain was really stretched but need a new chain and sprocket any how ( i was just trying to get the most out of it before needed adjusting everyday).
Old 06-05-08, 03:33 PM   #8
ScottishRawker
chain seems to be ok and tight enough, it wont make it until its moved slightly then when im in gear at a standstill with the clutch in, it will make the same noise if i rev it to 2k.
Old 06-05-08, 05:34 PM   #9
Alpinestarhero
hmm, difficult to offer too much advice without actualy experiancing it for myself.
Maybe you can get a video of it happening?
Matt
Old 06-05-08, 06:01 PM   #10
One clunk? A fast graunch? Describe it in more detail for us would you
clunking noise under braking nik_nunez SV Talk, Tuning & Tweaking 24 28-08-08 04:24 AM
clunking chain noise steveg Bikes - Talk & Issues 4 23-03-08 10:39 PM
Clunking sound over small to large bumps on a curvy Duck-man SV Talk, Tuning & Tweaking 21 13-12-06 07:26 PM
clunking starter? toyotafj40s SV Talk, Tuning & Tweaking 7 23-08-06 10:50 PM
chain is clunking rednorvs SV Talk, Tuning & Tweaking 6 13-11-05 07:08 PM
