Old 31-12-06, 03:14 PM   #11
furrybean
Was it that bad. These say 25 metres so they're not quite as bad as that
Old 31-12-06, 03:16 PM   #12
Sudoxe
Your be fine, just do as they say and bury the big ones before setting light to them.
I've had bigger display ones, and to be honest, just use a bit of common sense and your be fine. (i.e. don't stand next to it and look at it whist exploding)
Dan
Old 31-12-06, 03:18 PM   #13
furrybean
Well I've just found a piece of 32mm waste pipe that Ive sharpened to push into the lawn thats about 1m long. Will that be okay?
Old 31-12-06, 03:49 PM   #14
Supervox
No more Mr Nice Guy
Supervox's Avatar
Just make sure that the pipe is well anchored in the ground too ensure that it can't be blown off the vertical by either the wind or the force of the rocket when ignited.
Also, if you can stand the recommended distance away then do so - if not, then get as far away as possible.
Just one more thing, looking at the pic it doesn't appear to have a very long fuze (I'm assuming here that its encased by that orange bit - which I assume (again) is removable ?) so you might want to think about clearing a nice 'running track' to get you safely away when lit !!
If I'm wrong & there is no obvious fuze - DO NOT USE UNDER ANY CIRCUMSTANCES !!
Never argue with an idiot - he'll drag you down to his level and then beat you with experience
Supervox is offline   Reply With Quote
Old 31-12-06, 03:52 PM   #15
furrybean
Oh yeah there is a fuse about 70mm long, better take my running shoes with me then! Its forecast strong winds and Liverpool has called off their firework display. I'll take them but it looks like it wont be a goer!
Old 31-12-06, 05:21 PM   #16
K
You could always bring them along to the AE07.
Old 31-12-06, 05:24 PM   #17
furrybean
I could strap a rocket to my pillion to make me go faster
Old 31-12-06, 05:39 PM   #18
Flamin_Squirrel
Yes, I've heard it is common sense to avoid spontaneously exploding while standing near fireworks.
Old 31-12-06, 06:06 PM   #19
Sudoxe
Old 31-12-06, 06:32 PM   #20
fat_brstd
every year i use display fireworks at both new years and bonfire night. there is no need to worry. The only problem with rockets like that is that they tend to go very very high before exploding. this means you get a crick in your neck just trying to see them. Make sure you bury the cascade properly because if you dont it will fall over and thats when things start to go wrong.
have fun and remember warnings lables stop us from following the correct process of natural selection.
Advise please wilky007 SV Talk, Tuning & Tweaking 6 12-11-08 08:15 PM
not sure how to word this...advise please Dappa D SV Talk, Tuning & Tweaking 5 21-07-08 01:01 PM
advise for a new guy? jay boi Idle Banter 23 10-04-07 03:57 PM
Advise please aliBONG01 SV Talk, Tuning & Tweaking 10 02-08-06 06:44 PM
wax on , wax off - please advise. Warren SV Talk, Tuning & Tweaking 13 16-03-05 08:57 PM
