Old 15-01-07, 11:55 AM   #11
Did a spot of digging about, apparently the problem's around the sulphur content- sulphur's a great lubricant but under some conditions it's corrosive. That's all second hand, mind.
Old 15-01-07, 02:59 PM   #12
injury_ian
Additives
all boils down to... if it were any good it'd have a suzuki / honda / kawazaki etc badge on it
. or should i say castrol / silkolene etc
Old 15-01-07, 03:32 PM   #13
DanAbnormal
Well.........all I can say is that already I have felt a difference in how my bike runs. Runs a lot smoother, picks up quicker and also gear changes are so much smoother (no usual clunkyness). As for there being clutch problems, clutches on bikes are not metal/metal friction they are metal/mineral (so I've been told) so it doesn't do any damage. All I know is that I will be using it from now on.
Old 15-01-07, 03:44 PM   #14
Gazza77
Gazza77's Avatar
I wonder why none of the major oil companies use this in their engine oils
Formerly Blue K5 with added bits
Then Triumph Sprint ST with scottoiler and R&Gs & TOR exhaust
Now Benelli Tornado
Gazza77 is offline   Reply With Quote
Old 15-01-07, 03:50 PM   #15
PsychoCannon
At first I thought this was going to be another of those fuel pill things
Hmm not even going to pretend to know anything about this so I'll stick it out until I do know more
How much is this stuff out of interest.
Old 15-01-07, 04:34 PM   #16
Scoobs
Just read the testimonials on their website. Apparently Phil Read MBE uses this stuff and quite likes it. Interested to see the results from SV Dan.
Old 15-01-07, 04:49 PM   #17
sdusk
I won't get into an argument about whether it does what it says on the tin, but think about the following points:
- As RandyO will testify, a properly maintained SV engine will still be running strong after 120,000 miles +
- The only metal to metal contact in your engine is between the bores and the piston rings (and you really don't want that to be diminished). If anything else touches, then your oil pump has failed.
- Even if the product allows your crank pins to turn in the big end bearings after an oil pressure failure, the bearings will be hammered to death anyway in seconds (they are really very soft).
Old 15-01-07, 04:56 PM   #18
i used to use slick 50 in my cars years ago, has that stuff disappeared or can you still get it? i must say it is ment to do a great job but i never felt any diff.
Old 15-01-07, 04:57 PM   #19
Jelster
Activ8 ??? Last time I used something called Activ8 it was a killer bait for big carp....
Sorry, I'm not helping am I... However, I must say that the comments from sdusk make a lot of sense (well to me anyway).
Old 15-01-07, 05:23 PM   #20
tricky
I have been using a product called ZX1 in all my engines (4 strokes, 2 strokes, cars, bikes, everything) for about 5 years now and have really noticed the difference in terms of performance and fuel economy.
The Official Product Of The Olympics squirrel_hunter Idle Banter 3 05-08-08 08:13 AM
recommend me.... a leathers cleaner/ product John 675 Bikes - Talk & Issues 3 10-09-07 03:15 PM
Best Cleaning product MarkyBoy Bikes - Talk & Issues 8 25-07-05 09:57 PM
Defective product or just my hard luck? the oaf SV Talk, Tuning & Tweaking 2 03-12-04 10:39 AM
Anti corrosion product ACF-50 Baldyman Bikes - Talk & Issues 0 18-10-04 06:59 PM
