Old 21-02-07, 12:41 PM   #11
Jdubya
Default Re: ACF50.,..where to put it?
I use about half a can each time I do it.
I spray a bit in the top of the can then just paint it on using a paintbrush, that way it doesn't get everywhere you dont want it to like on the paintwork and brake discs...a can normally lasts me a good 6 months
Old 21-02-07, 01:01 PM   #12
cuffy
Originally Posted by Banus View Post
I use GT85 liberally which I hear is basically WD40 with teflon which creates a barrier to the elements. Again you can spray it on just about anything and acts as a lubricator and moisture displacement agent and rust inhibitor. Is it as good as ACF50 or same with a different name ? Also GT85 is cheap £4.49 a can from Halfords
I use GT85 too, it's nearly the same but not as efficient as ACF50, however i did coat the whole bike in GT85(Fairings n all) before i went to France and it did actually act as a barrier.
I PM'd fizz over this and this is what he said:
Theres two different types. Scottoiler make some stuff called FS365, its pretty good, but it has one drawback its water solluable so everytime you ride in the rain or wash your bike you have to reapply it.
If you can get it theres another product called ACF-50 which Northwind swears by, the use it on aeroplanes to stop them corroding. Its not water solluable so you just cover your bike in it and then come spring wash it off agani. Its supposed to be a much better product than the Scottoiler stuff. When I've run out of the scottoiler spray I'm going to get some.
HTH
Old 21-02-07, 01:22 PM   #13
sinbad
I heard you should be careful with around the gear lever and linkage, because it can get quite sticky. Nothing a bit of WD40 won't cure, but that's what I heard.
New bike - ACF50 or Vaseline? Tigerrrr....... Bikes - Talk & Issues 11 23-03-09 09:31 AM
best way to remove ACF50 from brakes? etuna SV Talk, Tuning & Tweaking 7 17-11-08 04:09 PM
ACF50 On Chain? svdemon SV Talk, Tuning & Tweaking 6 10-11-08 12:52 PM
Can you ACF50 brake calipers tomjones2 Bikes - Talk & Issues 6 15-11-07 10:25 PM
acf50 question steveg SV Talk, Tuning & Tweaking 13 03-01-07 08:28 AM
