Old 23-02-07, 07:47 AM   #11
steveg
steveg's Avatar
Default Re: Low side....20 minutes ago.
Bad luck , hope you & the bike mend well.
When I smashed up my fazer the throttle kept sticking open , the cause was that the handlebar itself was bent , causing the throttle grip to stick , or it could be the throttle / choke cables.
Take it easy
Cheers Steve
ex - red sv650s 06 reg
Now Triumph sprint 1050 ABS 05 Reg
AKA Papa Smurf
steveg is offline   Reply With Quote
Old 23-02-07, 01:41 PM   #12
gettin2dizzy
yeah, if you've knacked the choke so it sticks it would also cause the backfiring as you'd have lots more unburnt fuel passing through. Unlucky though! glad to hear your in one piece
Old 23-02-07, 05:09 PM   #13
Ceri JC
You tried leaving the bike running (in neutral, on the sidestand) for a minute or two?
I'm pretty sure the ECU sometimes gets itself in knots and gets sticky. Mine did the same thing after a crash. 2 minutes idling and it went back to normal and the problem hasn't re-occured since.
Old 23-02-07, 11:53 PM   #14
Torn-Thorax
It's a curvy
Old 24-02-07, 12:17 AM   #15
Ed
Having done something very similar, I sympathise
Old 24-02-07, 12:52 AM   #16
Torn-Thorax
Hmm now to repair the tank
Just missed out by minutes touch107fm Bikes - Talk & Issues 11 12-03-09 11:14 AM
5 minutes people, 5 minutes Dan Idle Banter 13 23-06-08 10:50 AM
So I turned my back for 5 minutes Kinvig Idle Banter 57 17-05-07 07:02 AM
5 Minutes late.... 10 Minutes early 454697819 Bikes - Talk & Issues 22 06-04-06 05:48 PM
