Old 01-03-07, 10:13 AM   #11
Viney
Default Re: Help! Nothing can move those screws!!!
Dont forget the 2 screws up underneath the rear fender. As for moving the screws. make sure that you have a decent screw driver, or failing that, get a screw driver attachment for a Ratchet bar(socket set)
Old 01-03-07, 10:20 AM   #12
andyb
Where did you get yours fron Nadine? I'm looking for one but dont want to end up with one of those frosted type ones.
Old 01-03-07, 10:41 AM   #13
timwilky
timwilky's Avatar
Once you have removed them with an impact driver, Throw them away and buy a couple of 6mm domed socket head stainless bolts to replace them. should cost all of about 50pence and make removal in the future far easier
Not Grumpy, opinionated.
Old 01-03-07, 11:11 AM   #14
amuli
Tap the screwdriver with a hammer, as you try and turn it. I had the same problem, they have been secured with thread lock to stop them vibrating loose.
Old 01-03-07, 12:10 PM   #15
Ceri JC
Originally Posted by thor View Post
Keep soaking the things in wd40 over a couple of days.
Good luck!
What he said. A screwdriver with a metal capped handle that you can hit (lightly) with a hammer with might also help break the seal and loosen it. Do this each day and apply WD40 liberally. After a few days, you might find it comes undone. I had some (external) bolts on my bike seized and it took about 4 days of this to loosen them, on the 4th day, they came off suprisingly easily- although they had still been rock tight the previous day.
Another tip, although not something I've tried personally (I read it in my Haynes) is to use a little valve grinding paste on the screwdriver head to get a bit more grip on the screw. Hopefully someone here should be able to confirm if this is a good idea.
Old 02-03-07, 08:00 AM   #16
Spanner Man
Morning all.
One point worth mentioning is, make sure you use a number 3 Philips screwdriver on these screws. As the more common number 2 will round the head off for sure. Then as Timwilky suggested replace them with Allen screws and a decent sized washer.
Cheers.
Spanner Man
Old 02-03-07, 10:21 AM   #17
ejohnh
Originally Posted by Spanner Man View Post
Morning all.
Cheers.
What he said, and it is always worth going out a buying a new decent screwdriver when you are faced with a 'seized up' screw(cant believe I said that!). Any sort of wear on the screwdriver head and you will banjax the screw.
When I was an apprentice(prehistory) we used a releasing oil called releasol or lusol, something like that. Used to always work.
ACF-50 seems to work ok as a releasing oil too.
Old 02-03-07, 10:40 AM   #18
21QUEST
21QUEST's Avatar
Morning all.
Cheers.
Very good point and in my experience, ****e screws apart, using wrong sized tool for the job is what causes a lot of problems.
I still do take a chance when I haven't got the correct tool at hand/inability to apply good leverage but have no one but myself to blame in the end
Ben
Nemo me impune lacessit.
Old 02-03-07, 11:08 AM   #19
Spider
Get a MAN to do it. Sod it i`ll pop round and sort it out for you, Valencia you say? i fancy a bit of a ride out
Old 02-03-07, 12:48 PM   #20
Ooh, cool... Look forward to seeing the pics once it's done, that's a new one by me.
The screws. Stig Photos 19 12-01-08 12:22 AM
screen screws kwak zzr Stuff Wanted 9 14-10-07 09:31 AM
Fairing screws Si Jonz SV Talk, Tuning & Tweaking 4 28-07-07 02:14 PM
Rounded off screws... Mike1234 SV Talk, Tuning & Tweaking 6 06-11-06 11:36 PM
tap and die set (AND SCREWS) Warren SV Talk, Tuning & Tweaking 15 06-07-06 08:56 PM
