Old 11-03-07, 07:21 PM   #11
Larry
Default Re: Changing the Rear Suspension (adjusting standard shock)
Originally Posted by BILLY View Post
What mileage has your bike covered? It sounds like your shock is getting a bit tired and could do with changing!
It's done 23,000 miles, when should I look at changing the shock?
Old 11-03-07, 09:47 PM   #12
BILLY
I'd say about now then it is well past its life span!
Old 30-08-09, 06:10 PM   #13
CamKrys
I'm a 9st girlie and want to take my nearly 20st friend as pillion. Can my K4 handle it and what adjustments would I need to make? Or do I need to make him eat less pies first?!?! =/
Thanks
Old 30-08-09, 06:57 PM   #14
Stu
Trinity
Stu's Avatar
Thanks
Yr bike could cope, but I would be seriously concerned about you being able to control the bike.
I can't imagine it would be a pleasant experience for you at all, never mind potentially v. dangerous indeed.
Why???
Old 30-08-09, 07:06 PM   #15
Bloody ell fire.
Tell him to eat less pies. Basically unless you fit a shock with a scaffold pole for a spring then the bike will be down on the bump stop and handle very unpleasantly. So safe enough but progress will be very slow!
Old 30-08-09, 09:34 PM   #16
7755matt
7755matt's Avatar
Im slightly concerned now.
Im 14st7 and it sound slike im too heavy for the bike, my other half is about the same as me (well a bit larger actually) and she'd like to go pillion.
Ive never carried a pillion before so Im guessing this is a bad idea?
Also a good excuse to make her do her test and get her own bike
7755matt is offline   Reply With Quote
Old 30-08-09, 10:19 PM   #17
Bluefish
It can be adjusted, look in the owners manual if you have one. Look at the top of the shock, there is a silver ring with steps in it (referred to as notches by most) As folks have said, use the C-spanner from the tool kit and move the notched ring clockwise to the tallest notch. This is the maximum preload which you will need witha 12 stone passenger.
With a 12 stone passenger and 12 stone rider, even with max pre-load the shock is struggling. Just adjust riding to suit.
is it different on a curvy, cos on a pointy you turn anti-clock for more pre-load.
Old 30-08-09, 11:48 PM   #18
Luckypants
Luckypants's Avatar
Must be then! My curvy was clockwise IIRC.
Old 31-08-09, 01:23 PM   #19
Bluefish
cancel that, the pictures in the pointy book are wrong, so as a result i have been riding around with it on minimum setting with 13 -27stone on it, still wasn't too bad, better now though, suzuki *****.
Adjusting a Curvy Hagon Rear Shock TheStudent SV Talk, Tuning & Tweaking 7 22-06-09 08:44 AM
adjusting Hagon rear shock on bike.....? etuna SV Talk, Tuning & Tweaking 7 21-03-09 08:32 PM
Adjusting Rear Suspension on SV Stoneyginger SV Talk, Tuning & Tweaking 5 27-04-08 06:29 PM
Changing rear shock.... How easy/hard Iansv SV Talk, Tuning & Tweaking 32 29-05-06 07:15 PM
Adjusting rear suspension Chris1 SV Talk, Tuning & Tweaking 8 22-03-05 12:26 PM
