Old 25-04-07, 06:11 PM   #11
Grinch
Default Re: R1 Battery
It don't like R1 as its to 'short'...
Old 25-04-07, 09:47 PM   #12
Robw#70
I run a YTZ7 which is what is used on CBR6rr racekit (its tiny), it seems to cope with the extra compression, but I doubt it will cope with lights etc, however I think there is a 9ah available.
Not cheap mind as yuasa seems to be the only one stocked by the distributers
Old 25-04-07, 09:53 PM   #13
chunkytfg
I use a 8ah one on my race bike which runs total loss( no i havent fitted the generator yet rob) and tbh it works and is able to crank the bike fine.
I know sarah(SV650racer) had am prblem restarting her bike last year as the bike got compressionlocked and the battery didnt have enough juice to turn it over but for me so far so good.
I know one mintwin rider who used a 3ah battery in his bike and it always started no probs.
Old 25-04-07, 09:56 PM   #14
Grinch, do you ever leave yours parked out in the cold and wet overnight? If so, you don't want a titchy battery The standard one's barely adequate in winter IMO...
Old 25-04-07, 10:40 PM   #15
Robw#70
You can fit a Hayabusa battery, 12ah but same dimensions as a ytx9
Old 25-04-07, 11:59 PM   #16
Busas use YT12ABS don't they? That's standard fitment for the curvy SV isn't it 150x87x105. According to Yuasa it's just 9.5ah and 175A CCA.
Perhaps a YTZ10S would be an option... 150x87x93, but it still has an 8.6 ah cap and 190A CCA- not much worse than standard but a bit shorter. If you remove the fuse retainer in the curvy you gain a lot of space- I have a taller than standard battery with the fusebox and CDI on top of it and there's still clearance to the seat.
Old 26-04-07, 07:24 AM   #17
embee
embee's Avatar
Use a YTZ type, the cold cranking current is better than the other types size for size.
Check dimensions on the yuasa site
http://www.yuasabatteries.com/battery_search.asp
pick a battery type, you'll get an application list, click "specification"
Old 26-04-07, 08:06 AM   #18
Grinch
Well the battery is for the other SV, so in the winter its going to be on a 'trickle' charger or out of the bike all together. Will have to give the site a good going over.
Old 26-04-07, 08:29 AM   #19
svrash
I had a TL batt in mine for a year but they're twice the size but gave better cranking........no help really
Optimate battery charger drains the battery flymo Bikes - Talk & Issues 10 10-06-09 10:41 AM
What battery? richie95 Bikes - Talk & Issues 11 15-06-08 08:35 AM
The Battery??? SV PILOT Bikes - Talk & Issues 8 30-03-08 10:06 PM
Battery woe seandixie SV Talk, Tuning & Tweaking 1 14-09-06 04:11 PM
Battery/Starting problem - new battery hasnt fixed it! Aaron SV Talk, Tuning & Tweaking 13 24-01-05 05:21 PM
