Old 02-08-07, 10:39 AM   #11
600+
Default Re: Cold Water Hammer
cheers Sid - because it is not happening in any other house on my street I believe it is sthing to do with the tap so i'll give the washers a try first
Old 02-08-07, 10:48 AM   #12
Jelster
Squidster, the font of all knowledge for anything that's mechanical
Generally it's down to insufficient pipe support, it can be worsened by ceramic disc taps - they shut quite abruptly and cause the quick static pressure rise that sometimes causes the hammer in pipework that can move.
If the pipes can't be suitably fixed, there are devices that can be fitted to the incoming main to reduce hammer, essentially they're in two forms:
1) A pressure reducing balanced valve, like the regulator on a gas bottle or a DV if you're a diver, (Jaques Cousteau apparently used a modified camping gas regulator for his first experiments in Scuba breathing apparatus).
2) A piston in a pipe with a spring behind it, when the pressure rises as a valve is shut the piston displaces and the slows the static pressure rise.
Old 02-08-07, 11:55 AM   #13
Tris
Alternativly, take a "T" off the cold water supply and connect it to a 80 foot pipe that sticks straight up in the air
But on second thoughts Sids idea is tidier
Old 02-08-07, 07:00 PM   #14
chazzyb
Great idea! But what happens when the reservoir is more than 80' above you? Mmmm...
Old 02-08-07, 08:03 PM   #15
embee
embee's Avatar
If all else fails with the tap, you may need a shock arrestor, especially if the tap is at the end of a long pipe run. Sometimes just a different type of tap design with the pipework you have will cause the jumper to vibrate, it happens.
Something like a Watts Micron Shock Arrestor, http://www.lunns.net/ , usually around £20 inc. might do the trick.
Washing machines etc are usual culprits for causing a shock with a sudden shut off.
If it's a vibration then it's often inadequate pipe supports.
Recomend me a hammer... Grinch Idle Banter 41 15-01-09 05:48 PM
the cold kwak zzr Bikes - Talk & Issues 37 26-03-08 05:51 PM
Might aswell have a Hammer thread SteveH Idle Banter 2 06-11-06 01:29 PM
How to get it going when it's cold. Mark_h SV Talk, Tuning & Tweaking 10 01-01-06 09:09 PM
It's cold out there Moriarty Bikes - Talk & Issues 9 24-02-05 08:39 PM
