Old 02-09-15, 05:17 AM   #11
Red ones
Red ones's Avatar
Default FI light comes on with high sustained speed?
Has the bike got wet recently?
Old 02-09-15, 07:18 AM   #12
bs8c
Default Re: FI light comes on with high sustained speed?
I did my stv and tps less than a month ago...but after that i lso put a tre. Could that be the problem? I'll try to adjust them again cuz i see the tps is not set correctly.
Old 02-09-15, 08:24 AM   #13
Red ones
Red ones's Avatar
I'd check electrical connections, clean them and spray them up.
How old is the bike?
Old 02-09-15, 09:20 AM   #14
bs8c
Due to my lap top's hdd beeing a bi*ch and not wanti g to work..i'm limited to browse the net on my phone for now. So if you have some valid links of helpful information on this subject it wojld be great, if not...i'll have to browse after a week or so when i fix the lap top. I try to browse youtube cuz it's easier on the phone, and i found a good tutorial about tps on a tl1000.
Old 02-09-15, 03:02 PM   #15
glang
Hi Dan, I had the same problem and code sometime back and sorted it myself after some hassle. Search my previous posts and see if it helps as the issue never came back and I still have the same bike.
Old 02-09-15, 03:51 PM   #16
bs8c
Oh, it's a 04 sv650 and no, it havebt been wet recently(more than a month)
Old 02-09-15, 05:27 PM   #17
i would also check the connectors associated with the fuel system as one of them might have a furred up pin. this happened to my RR and its a waterproof connector. trouble with waterproof stuff is if water gets in it stays in.
Old 04-09-15, 07:51 AM   #18
bs8c
The plug on the stva wasn`t actualy in...this time i put it in and it clicked. Lets hope it`ll work. I also adjusted the tps and the stvs so..later tonight i`ll give it a test ride
Old 04-09-15, 05:30 PM   #19
Toooldtodie
Toooldtodie's Avatar
Sorted??
BTW what is a secondary throttle valve? And for that matter where and what is the primary? Oh, and what's a TRE?
Yeah, yeah I know... Google it. Every day a school day.
Thought I was in a bad mood, but it's been 30 years now, so I suppose it's just who I am.
05 SV650s now with proper suspension, hurrah!
Toooldtodie is offline   Reply With Quote
Old 04-09-15, 05:45 PM   #20
Toooldtodie
Originally Posted by Toooldtodie View Post
Sorted??
I am enlightened!
Still don't know what a TRE is though... keepes telling me I've spelt tree wrong!
Thanks in advance.
High-beam light simesb SV Talk, Tuning & Tweaking 2 27-03-08 07:22 PM
R1 does high speed run over 35km on SA road...(vid) Jdubya Idle Banter 11 18-06-06 09:38 PM
High speed wobble SV1000 retrofly SV Talk, Tuning & Tweaking 9 16-05-06 09:52 PM
Apologies if you've seen it before, pretty high speed vid rubberduckofdeath Idle Banter 3 06-04-06 11:09 AM
Idle Speed Change (too high) greeno76 SV Talk, Tuning & Tweaking 4 22-06-05 08:23 AM
