Old 08-09-07, 08:15 PM   #11
rictus01
rictus01's Avatar
Default Re: No Spark
I was doing using a jump lead, but with a pin in the end of the HT lead then the spark will go anywhere it should, engine bolts, coil mounting, subframe etc. without the jumplead connected.
????? so are you providing a negative from the battery or a live, I'm a little confused ?
Old 08-09-07, 08:22 PM   #12
OK test setup is like this:
coil +ve fed as normal via ignition main live feed.
coil -ve on test lead, brush test lead against frame (any earth) to test
plug/pin in HT lead end held against frame to test for spark
I had assumed a bad earth and conected the battery -ve to the frame/engine with another lead, but this seems to make no difference.
Now the plug caps are out of the way then this is producing sparks up to 1/4inch long as I would expect
however
cranking the engine with everything connected, still no spark.
Old 08-09-07, 08:30 PM   #13
rictus01
rictus01's Avatar
so are you saying the coils are just providing a connection and the (negative) test lead sparks on any earth reguardless of engine turning or only when the start button is pushed ?
Old 08-09-07, 08:32 PM   #14
the -ve terminal of the coil, when tapped against earth, makes the plug spark.
this is how it should be I think.
however with the -ve coil terminal connected to the black box as normal and the engine turned over there is no spark
Old 08-09-07, 08:45 PM   #15
rictus01
rictus01's Avatar
so what you're saying is the switched earth from the ignition unit isn't working to either coil.
if this is the case, buzz out the path back to the unit from the coil, then check the altinator housing for the pickup and wire back to the ignition unit as if it doesn't get the timing signal it won't switch it.
Old 08-09-07, 08:49 PM   #16
rictus01
rictus01's Avatar
could also be the old rubbed wire problem around the rear subframe.
Old 08-09-07, 08:51 PM   #17
the switched earth shows continuity and all that section of wiring is new so should be sound
the pulse coil resistance is in spec, but I don't have the "peak voltage adaptor" described in haynes to check what voltage its producing
the ICU is definately getting 12v supply and the 2 earths that go to it.
Old 08-09-07, 08:58 PM   #18
rictus01
rictus01's Avatar
which only leaves the pickup or an internal ignition unit problem, they have been known to go, anyone near you can come over and you try their unit ?
Old 08-09-07, 09:01 PM   #19
Maybe dizzyblonde but it's going to be hard convincing her lol
If I try my ICU in her bike, is there a risk of damaging components of hers if it is faulty?
Also where to get a spare pickup coil to try?
Old 08-09-07, 09:04 PM   #20
rictus01
rictus01's Avatar
no you won't hurt her bike by trying you unit in it, as to the pickup, best to remove the whole side and disconnect the wire and leave the pickup fitted to it.
no spark,no AR for HOVIS hovis SV Talk, Tuning & Tweaking 18 09-07-07 10:18 AM
Help, no rear spark... no AR Grinch SV Talk, Tuning & Tweaking 22 28-06-07 11:16 PM
no spark hovis SV Talk, Tuning & Tweaking 10 27-06-07 03:19 PM
spark plugs daddy_sperm SV Talk, Tuning & Tweaking 12 01-03-06 06:12 AM
No spark...please help. leegriffiths128 SV Talk, Tuning & Tweaking 0 11-11-05 05:17 PM
