Old 27-06-07, 03:36 PM   #1
Grinch
Default Help, no rear spark... no AR
In a continuation from this thread I have been working on Helga most of today, mainly to get her ready for the AR but also to find out why the hell I have no rear cylinder spark.
Now this is what I have done so far...
  1. Replaced the spark plugs and tested them for a spark on my other SV.
  2. Tested and swapped the coils from the other SV.
  3. Swapped the CDI from the other SV.
  4. Tested the voltage from the front coil, ignition on 10v dropping to 8v when engine is turned over.
  5. Tested the voltage from the rear coil, ignition on 12v increasing to 14v when the engine is turned over.
  6. Tested the green and white/blue wires in to the CDI as discribed in my manual which states there should be 3v or more, I'm only getting .03. It states that this is a failed signal generator, but as Sid pointed out to me if this is the case then why is the front plug sparking.
So I've run out of ideas, and now I'm testing the wiring as per Sids advice but I need some more pointing incase this fails too.
Plus I would like to say if this don't get sorted I ain't coming to the AR
Old 27-06-07, 03:39 PM   #2
wyrdness
Default Re: Help, no rear spark... no AR
Broken / damaged HT lead? Have you tried swapping it with one from the other SV?
Old 27-06-07, 03:42 PM   #3
hovis
this is spooky
http://forums.sv650.org/showthread.php?t=92199
i just cleaned all the connectors i could see
Old 27-06-07, 03:45 PM   #4
Grinch
As in step2 the whole coil was swapped.
Old 27-06-07, 03:45 PM   #5
Lozzo
Take the other SV instead...job done.
Old 27-06-07, 03:46 PM   #6
Ceri JC
You have PM.
Old 27-06-07, 04:15 PM   #7
Grinch
OK, rain has stopped play and now I'm not getting any spark anywhere. Back to the manual.
I would but its not ready yet, yes its running but it has no MOT or tax. Plus it needs another week of work to get it to riding standard.
Originally Posted by Ceri JC View Post
You have PM.
Thanks for the offer...
Old 27-06-07, 04:18 PM   #8
Skip
Skip's Avatar
I cant help with your problem Grinch but you better come as I have packed the Mokos now and as they are at the bottom I cant be bothered to unpack them now!
'81 Honda H100A
'18 Honda MSX125 (Grom)
Old 27-06-07, 04:27 PM   #9
Grinch
  • Tested the green and white/blue wires in to the CDI as discribed in my manual which states there should be 3v or more, I'm only getting .03. It states that this is a failed signal generator, but as Sid pointed out to me if this is the case then why is the front plug sparking.
Well it looks like now I have no sparks anywhere so it looks more and more like its the signal generator, which in turn I will need me to drop all the oil out of the SV (the signal generator is behind the alternator cover). Now I want to be sure of this as if I use the spare I'm going to have to drop the oil out of both SVs.
Old 27-06-07, 05:03 PM   #10
You don't need to drop the oil out, if you have the bike upright - on a stand for instance, a bit will spill but you'll only require a top up when you're done.
Alternatively lay it on the grass/a blanket/etc and none will be lost.
Mk3 Golf, no spark... rubberduckofdeath Idle Banter 7 29-05-08 10:03 AM
No Spark yorkie_chris SV Talk, Tuning & Tweaking 27 15-09-07 05:29 PM
no spark hovis SV Talk, Tuning & Tweaking 10 27-06-07 03:19 PM
No spark...please help. leegriffiths128 SV Talk, Tuning & Tweaking 0 11-11-05 05:17 PM
spark plugs weegaz22 SV Talk, Tuning & Tweaking 4 04-08-03 05:04 PM
