Old 21-09-07, 06:10 PM   #11
Ollie_07
Default Re: Removing the baffle - fuel exhaust
Originally Posted by colinsv25 View Post
is it the 1 with removeble baffle or the 1's u ave to drill out
the removable one with the allen key headed screw. No drilling needed apparently..
Old 21-09-07, 06:12 PM   #12
plowsie
Originally Posted by Ollie_07 View Post
cheers mate
Would the can being warm help at all, like if i left the engine running for a while?
may do yanno
give it a try
Old 21-09-07, 07:46 PM   #13
Can try it a bit warm to loosen it, or save the hassle, cause every time you grip it it distorts and holds in harder.
So, take the can off, take the bolt out and stick a broom handle down the can, it really is the easiest way.
Old 21-09-07, 07:53 PM   #14
mclarenmike
Just fitted a fuel exhaust but cant get the baffle out.
Ive undone the small screw but the baffle is still solid and doesnt look like there is any give in it!
Am i doing something wrong?
Helppppppppppppp!
Had exactly the same problem as this. Best solution is to get a mate to hold the exhaust "steady" whilst you pull really hard on the baffle with pliers... trust me it'll come out.
Enjoy the sound post baffle!!
Old 21-09-07, 09:33 PM   #15
dont know about fuel can's but scorpion can baffles are siliconed in to help with noise reduction, they need a good tug to get them out or as others have said get a broom handle up the other end and knock it out.
Old 22-09-07, 08:01 AM   #16
Ollie_07
Balls, oh well ill perhaps try the broom thing today. Suppose its another opportunity to start it up with no can on!
Wanted to pop out on it today to see what its like when riding as its meant to be sunny, woke up and its ****ing down.....gutting!
Old 22-09-07, 08:02 AM   #17
Ollie_07
Old 22-09-07, 08:13 AM   #18
jumjum_0214
The sun will be out in a bit mate
Old 22-09-07, 09:36 AM   #19
Ollie_07
The broom handle thing worked a treat!
Sounds awesome, cant wait to give it a test ride!!
I just hope your right now JumJum! need some sun!
Old 22-09-07, 10:25 AM   #20
Told u so
You want to be careful though, doing the same has given me a bit of a twitch, can't go under bridges at anything less than full throttle
Fuel exhaust baffle out, increase power? flimbar SV Talk, Tuning & Tweaking 12 23-06-08 08:35 PM
Fuel Exhaust removeable baffle - help needed! mattyL Exhausts 14 15-01-07 11:32 PM
removing baffle remus will Exhausts 11 20-02-06 08:35 PM
Removing a baffle from ccc can Kirmit Exhausts 7 09-02-06 10:43 AM
Removing baffle on Yoshi can Anonymous Exhausts 2 05-05-05 07:07 PM
