Old 08-02-08, 06:00 PM   #21
NedSVS
Default Re: Cam swap - proce for a garage/experienced SVer to do the job?
At a guess I'd say you'd have to set the clearances if you fit different cams as I doubt the 0 lift part of the cams will be exactly the same on each camshaft.
When I did mine I measured the clearances with the old cams and adjusted the shims as needed assuming the new cams would be ground accurately. The result was spot on!
Old 08-02-08, 06:18 PM   #22
Yep, same here, the runout was almost identical when I swapped mine. Didn't really expect it but it seems to be pretty common.
Old 08-02-08, 07:40 PM   #23
Ah that's good, didn't think they'd be that accurate.
Old 11-02-08, 12:42 PM   #24
johnnyrod
johnnyrod's Avatar
Same here, which I have also read for everyone else who did it. Strange but true
Experienced bikers Fearg Bikes - Talk & Issues 23 11-11-07 08:05 PM
Fully fledged SVer Lozzo Bikes - Talk & Issues 1 11-08-07 07:59 AM
anyone got/experienced vista ? Warren Idle Banter 31 30-04-07 04:24 PM
Moral: Always listen to those more experienced! PointyPete Bikes - Talk & Issues 25 23-12-06 12:55 PM
For experienced riders... keithd SV Talk, Tuning & Tweaking 20 08-09-04 09:54 PM
