Old 10-02-08, 05:31 PM   #21
Blue_SV650S
Default Re: Back brake pistons (at wits end)
I use a small g-clamp to hold the piston/pistons I don't want to move.
+1! ... G-clamp is essential kit for callipers
Old 10-02-08, 06:27 PM   #22
petevtwin650
Zip/cable ties are really strong especially in the more chunkier sizes.
Old 10-02-08, 07:11 PM   #23
Where can you get stainless pad retaining pins?
Old 10-02-08, 07:19 PM   #24
Blue_SV650S
A g-clamp is re-usable and helps push stubborn pistons back in
Old 10-02-08, 07:21 PM   #25
petevtwin650
Agreed but if you've done the job properly they should just push in by hand.
Old 10-02-08, 07:22 PM   #26
dirtydog
Knob faced knobster
dirtydog's Avatar
I got mine off ebay a while ago now. I had a check earlier and cant find who sold them although i spose if you've got some tools you could even make some yourself from some 5mm stainlees steel rod the awkward bit will be drilling the hole for the r clip to go through
2011 Speed Triple 1050
Old 10-02-08, 07:25 PM   #27
Indeed, is it really necessary to upset the end like on the standard one?
If so then could turn down a stainless bolt to shape. Which will be a bugger, but oh well.
Old 10-02-08, 07:29 PM   #28
Blue_SV650S
If you don't push them in 100% true, they can jam ... Mr G-Clamp sorts that
Anyway, yes hold it back with anything, but I like using a g-clamp
Old 10-02-08, 10:08 PM   #29
Tiger 55
Originally Posted by thedonal View Post
All back together and the little bleeder's been bled!
I'm conducting a survey. Which bleeding method did you use mate?
Old 11-02-08, 09:19 AM   #30
thedonal
Mityvac. Just took it in turns front and back bleed nipple.
The Mity is quite good- but can be a little hard to tell if the pipes not on the nipple too well as it pulls air in around that as well as from the brake system.
I suppose a bit of ptfe tape might help that (Gah! Now I think of that), but the ensuing froth can make it hard to check the condition of the fluid. Though this is more of a problem on the back bleed nipple once the brakes bolted on again, as it's more awkward to get to.
Still- having had to bleed the system 3 times to get both pistons out and re install the caliper, I can confirm that it does help the whole operation.
2 people and a 1 way valve bleed system (just a little pipe with a ball bearing in it) is also pretty good- this is how DirtyDog did the front calipers last weekend. In fact, 2 people doing it really makes a difference.
Best way to clean up brake pistons? curium SV Talk, Tuning & Tweaking 12 06-04-09 09:42 PM
Brake Pistons? vardypeeps SV Talk, Tuning & Tweaking 4 29-08-08 12:12 PM
scaring on brake pistons huge SV Talk, Tuning & Tweaking 2 13-01-06 04:32 PM
new brake pistons and seals. where from? raymond smith SV Talk, Tuning & Tweaking 2 30-04-05 09:24 PM
Rear Brake Pistons JMCHITTOCK SV Talk, Tuning & Tweaking 8 22-02-05 09:23 AM
