Old 01-05-09, 03:26 PM   #21
drag
Default Re: rearset replacement
Originally Posted by CheGuevara View Post
That's right. And yeah no more spring, bu the line pressure is enough to return it, especially with the bearing in the lever.
Originally Posted by flymo View Post
On the new rearset you have a smaller hole just in front of that silver bolt in your picture. Thats probably for the spring. It will need a spring or it wont return to normal position.
....or, there seems to be a slight indentation in the middle of that silver bolt itself, maybe they intend for the spring to hook around that.
i'm thinking Che might be right, based on the angle of the sets and the current springs location i'd say that if the spring were attached it would cause the lever to push down instead of lift up.
Old 01-05-09, 03:31 PM   #22
flymo
flymo's Avatar
I'm not so sure about that, lookign at the lever assembly in post #13 the hole looks perfectly positioned for a spring to pull vertically downwards (I incorrectly said upwards....doh)
I would always expect for a spring to be there to return the lever, you cant rely on fluid pressure alone. The fluid is not exerting any pressure to fully return the lever, only part way.
Old 01-05-09, 03:31 PM   #23
CheGuevara
Correct - I've edited that post, but the extra hole (same size actually) is just to ensure you can align the master cylinder and/or change leverage ratio. I used the outboard hole.
CheGuevara is offline   Reply With Quote
Old 01-05-09, 03:34 PM   #24
CheGuevara
I'm not so sure about that, lookign at the lever assembly in post #13 the hole looks perfectly positioned for a spring to pull vertically upwards.
It would pull upwards but on the wrong end as Drag noted -it would be applying the brake instead of returning the lever to home. Line pressure alone does the trick -with the bearing in the lever there's very little resistance. There no return spring on your front master cylinder right?
Old 01-05-09, 03:38 PM   #25
flymo
flymo's Avatar
Yeah I made a typo, edited at the same time you were replying.
I cant see it causing a major problem without a spring but thats the reason the stock lever has one. Front brakes are different as there is no lever acting downwards, other thing to watch out for with no spring potentially is the front of the lever touching the ground when fully leaned over.
Old 01-05-09, 03:39 PM   #26
drag
Good point actually, worst case i'll bodge up some sort of crazy looking bracket, but i doubt i'll need it, prob wont get to do the work on it now till monday anyway, have to go see about a rejetting tomorrow
You chaps have been a huge help, and as always if anybody reads this in the future, these gbmoto sets are quite nice !! and a decent price also
Old 01-05-09, 03:41 PM   #27
flymo
flymo's Avatar
I have Diamond race rearsets on mine, very similar to yours. I'll take some snaps of the spring arrangement when i get home for you.
Old 01-05-09, 03:46 PM   #28
drag
Ahh cool that would be nice to have.
Old 01-05-09, 03:51 PM   #29
CheGuevara
I agree 100%. I bought mine mostly for the bling, a bit for the adjustable position -but was pleasantly suprised how much better the shift action was. The price is a bargain for what you get -far cheaper than any other adjustable sets I could find and quite nicely made.
Old 01-05-09, 03:52 PM   #30
drag
The only thing i would add is it's shame there black and not silver, but maybe i'll get the fame powercoated at some stage ...
Looking for: LHS Rearset - 99 Curvy JimmyGulp Stuff Wanted 6 04-07-08 03:41 PM
Rearset bracket plowsie Stuff Wanted 4 03-07-08 10:43 AM
rearset Compatability andyb SV Talk, Tuning & Tweaking 25 27-09-07 07:41 PM
I designed some rearset for SV r4ce_e3nd SV Talk, Tuning & Tweaking 16 10-11-06 09:59 AM
Rearset fitting rigor SV Talk, Tuning & Tweaking 4 11-12-05 05:24 PM
