Old 11-04-08, 03:48 AM   #21
zadar
Default Re: SV1000 throttle bodies on a 650?
Yeeeas but they're big-bore with cams and porting. IIRC. Also still nowhere near the size of the TL TB's.
stock motor with cam swap.
only difference between runs is bored tb's.
Old 11-04-08, 03:50 AM   #22
zadar
and this is 2mm over motor,again same change,tb's.+ 4hp.
Old 11-04-08, 03:55 AM   #23
zadar
and not only on sv but also on ninja 650.
difference between red and blue is 6mm bigger tb's.
Old 10-12-09, 11:11 PM   #24
antony
does any one know the procedure for this do you bore all the way down do you have to make new butterflys any help appreciated.
Old 10-12-09, 11:38 PM   #25
fastdruid
fastdruid's Avatar
So to sum up, bigger TB's are good for ~4BHP but do TL/SV TB's fit or not?
Or are they too big?
Or would the EFI not cope without a (very expensive) custom EFI ECU?
Not that I care having a carbed curvy but I keep thinking about having a play with FI[1]
Druid
[1] And megasquirt
Old 11-12-09, 01:16 AM   #26
zadar
both
Old 11-12-09, 05:07 PM   #27
antony
ok cheers i have a lathe so not a problem i gues you have to make the butterflys as these cant be bought off the shelf 2mm bigger
thanks all
Old 11-12-09, 05:53 PM   #28
Ratty
Ratty's Avatar
The 650 and 1000 lumps have the front cylinder off set opposite hand so they couldn't fit regardless of size.
Ratty
"I can see Paradise by the SV's light"
TCX Competizione S boots saved my foot .
Ratty is offline   Reply With Quote
Old 11-12-09, 06:57 PM   #29
Meh. TB's are only on steel plate. Easy to move, just remake plates and linkage, easy to offset. Have welder, will hammer.
But as zadar says you don't gain much over bored TB's to huge ones like TL.
There is a point that whatever you gain in reduced dP you will lose in reduced charge velocity and charge mixing.
Old 11-12-09, 07:54 PM   #30
fastdruid
fastdruid's Avatar
AFAIK SV1000 have 52mm, SV650 39mm and the graphs are from what, 2mm over so 41mm? So SV1000 (and presumably TL) are massively large then.
You'd probably be better off trying a set of hayabusa TB's (44mm AFAICT) if the SV1000's wont fit straight on, might even be able to re-use most of the existing bits from the 650's TB's. They are after all designed for *exactly* the same size cylinder!
I'd try it myself but I've got a curvy
Druid
Removing throttle bodies muffles Bikes - Talk & Issues 4 19-04-09 12:50 AM
Pointy 650 throttle bodies svdemon For Sale - SV's and SV related items 2 15-04-09 02:49 PM
sync throttle bodies olden mgroin SV Talk, Tuning & Tweaking 5 29-09-08 07:41 PM
Throttle bodies???On a Raptor dizzyblonde SV Talk, Tuning & Tweaking 8 21-06-07 02:13 PM
