Old 13-04-08, 07:58 PM   #21
fizzwheel
fizzwheel's Avatar
Default Re: SV650s Smoking on Overrun and Downchange
*EDIT* Has also had a tendency to not find Neutral easy unless I fiddle about ot turn the engine off ??????
Yep thats cause its got to much oil in it. Its quite a common reason for not being able to find neutral or a notcy gear change in general.
Old 13-04-08, 07:59 PM   #22
fizzwheel
fizzwheel's Avatar
Originally Posted by lloyd_christmas View Post
If you let oil out by undoing the sum plug, it will be rather painful putting it back in if the engine is hot.
True its also easy to drop the sump bolt in the oil catch tray to
Old 13-04-08, 08:00 PM   #23
xXBADGERXx
Looks like we have found the culprit then , gonna go into Woods tomorrow , grab somebody by the ear and march them outside and point and say "Cure this or somebody gets a Knuckle Supper"
Cheers for the input everyone , will take her back after work tomorrow and will let you know the outcome of it all
Old 13-04-08, 08:00 PM   #24
lloyd_christmas
How does that work?
Old 13-04-08, 08:01 PM   #25
fizzwheel
fizzwheel's Avatar
How does that work?
No idea, but I over filled my own SV and my other halfs SV to. Both times the gearbox was orrible and notchy.
I'm not the only one thats noticed this either, plenty of people on here have done the same and noticed the notchy gearbox.
Old 13-04-08, 08:03 PM   #26
lloyd_christmas
I used to use an old 5L oil container with a hole cut in the side. It was handy, as i could then decant the used oil into another container and screw the lid on it.
It was a proper **** when i dropped the sump plug into it though
Old 13-04-08, 08:03 PM   #27
Wideboy
Evel Knievel
Wideboy's Avatar
+1, i also found it did this when the oil reached 4000 miles
05 DRZ400E
RIP hovis
Old 13-04-08, 08:04 PM   #28
lloyd_christmas
I have not heard that before, thanks.
Old 13-04-08, 08:45 PM   #29
Remember there's no real need to do this with the engine hot. Boiling oil is not nice!
Old 13-04-08, 08:53 PM   #30
xXBADGERXx
Well the bike is under warranty , so I`ll drop it off at dealers tomorrow and they can lend me a courtesy bike for the day , or they can wait for the oil to settle and drain some out whilst I wait .
No smoking thinone Idle Banter 25 06-09-08 07:46 AM
Smoking ban to end!?? keithd Idle Banter 75 08-12-07 04:06 PM
Overrun issues and decreased fuel capacity Al_Sweetman SV Talk, Tuning & Tweaking 9 27-09-07 09:09 AM
Smoking 2 STRAMASHER Idle Banter 0 26-04-06 02:24 PM
Issue with K3 on the overrun Robbo_ SV Talk, Tuning & Tweaking 0 15-01-06 07:14 PM
