Old 06-09-08, 04:14 PM   #21
fastdruid
fastdruid's Avatar
Default Re: so ... Injected or not injected
The SV (if it's a UK model) has carb heaters that should prevent carb icing, trouble is that the sensor has a habit of not being in the best place[1] and if you're not carefull it'll sit somewhere a tadge warmer than ambient.
Druid
[1] It's just loose, from memory it's a black D shape, around the size of a pound coin and normally sits around the right front of the frame.
Old 06-09-08, 04:16 PM   #22
fizzwheel
fizzwheel's Avatar
It does but they dont...
Best fix is as posted above, run it on premium fuel, Shell Optimax used to sort mine out in the winter if I did get carb icing, but it wasnt very often. IMHO its not a big thing and I wouldnt let that one particular niggle put me off buying a bike if it was the right one.
Old 06-09-08, 04:41 PM   #23
fastdruid
fastdruid's Avatar
Exactly, mine didn't until I moved the sensor so it sat in the airflow rather than against the frame. Made the world of difference.
Still, going for a fuel additive is easier and will still work even when the fuel heaters aren't.
Druid
Old 06-09-08, 05:05 PM   #24
Spokey
Thanks for all the replies - well, went over and had a listen and a look -
fetching it next weekend 2003 pointy naked in Blue.
Blue flame twin exit cans sound nice don't they - how could I not buy it !
Thanks
Nana
Old 06-09-08, 05:22 PM   #25
I've done that too, didn't make any difference... I suppose it depends on the conditions you ride in, they're good enough to deal with mild carb icing conditions but not bad ones.
Sv650s k3 injected SV-Sexy-virgin? SV Talk, Tuning & Tweaking 3 23-03-09 10:35 PM
K5 or above injected engine metalmonkey Stuff Wanted 0 01-10-08 01:06 AM
Injected Clocks RGV250ads Stuff Wanted 6 16-07-08 08:14 PM
JHS Bodywork available - Injected SV RGV250ads Mini-Twins 6 15-07-08 07:36 PM
Anyone know of a used injected SV for sale? northwind SV Ecosse 6 13-06-06 04:24 PM
