#21 |
I can get it lightened and balanced for you, cost though is about £400 for lightening and balancing and £200 for balancing. We have had great success with this and the SV crank can safely loose 1kg which makes a big difference in terms of reliability and how the motor makes its power.
#22 |
No I didn't bother as the crank I was going to use was chowed up to death.
Might try hard welding it and machining it back... maybe. But that is a while off
#23 |
coming from the automotive engineering field, i can tell u how its done. it's called blue printing, and u need a machine to do it. u would do the crank with the flywheel and cluch assambley.but not with the rods or pistons they will be done one at a time, the pistons and rods u can do yourself with a very acurate scale. if u need any help on how to do the rods and pistons drop me a msg and i will talk u threw it, thanks jarrod
#24 |
You wouldn't do it with clutch fitted to SV. Flywheel can also be lightened a lot or changed for a trick one.
#25 | |
#26 |
at a guess less stress on the bearings ?
YC how much did the busa pistons cost ? suzuki GB are coming up at £119 each but in the us there are $100 each |
crank 2 | zsv650 | Idle Banter | 12 | 25-04-09 10:17 AM |
crank is on tv now | zsv650 | Idle Banter | 19 | 17-04-09 02:04 PM |
Help! What years are pointies, and does the crank swap? | thelilbigtony | SV Talk, Tuning & Tweaking | 3 | 27-12-08 04:14 PM |
in need of a crank | thelilbigtony | Stuff Wanted | 9 | 27-12-08 02:04 AM |
Crank Shaft Needed *Urgently* | roadrace | Stuff Wanted | 3 | 17-07-08 05:18 PM |
