Old 22-10-08, 07:16 PM   #21
hovis
Default Re: flat battery
Originally Posted by 600+ View Post
bare in mind that the optimate only sends through a small current to keep the battery alive. it's not one of those trickle charger things that charges the battery fully in a couple of hours.
different things
but it will charge it fully over time?
Old 22-10-08, 07:18 PM   #22
fizzwheel
fizzwheel's Avatar
I believe it does if you leave it long enough. I've used it to recover flat batteries in a few hours. It even put enough juice into my GSXR in 20 minutes so that the bike would start. But the battery wasnt completely discharged in that case though.
Old 22-10-08, 07:20 PM   #23
hovis
i have the 2 green lights, but going to leave it on
either till tomorrow or monday
Old 22-10-08, 07:29 PM   #24
Stu
Trinity
Stu's Avatar
til Monday!!!
Old 22-10-08, 07:31 PM   #25
hovis
Originally Posted by Stu View Post
til Monday!!!
monday it is then good sir..........
what then? take it for a spin and leave it then try the day after?
i have a big rideout planned for saturday, so i may need a push
Old 22-10-08, 09:05 PM   #26
thefallenangel
the two lights on mean the battery is as charged as the optimate will get it, not that it will start the bike. Charge it enough to start the bike, take it out for an hours run and leave the bike for a day and see if it discharges. If it does the battery is being drained off by something or is knackered (and as you haven't added anything recently i'd say it's knackered).
Old 22-10-08, 09:25 PM   #27
tigersaw
tigersaw's Avatar
Once the green light comes on it means it has stopped demanding 90% of the charge current it began with. It is still charging, and then will go into conditioning mode, where it will monitor the batteries self discharge rate, then charge again. The red 'knackered' lamp can come on many hours later after it has evaluated for a while. This doesn't always mean the battery has failed, but that something has been drawing current whilst the evaluation has been going on. If this occurs the test is to remove the +ve lead from the battery to the bike, or remove the battery, and try again. Leaving it connected for days or weeks at a time is nothing but beneficial.
Old 27-10-08, 01:18 PM   #28
hovis
its been on charge since thursday, so im goin out this afternoon, then i will see what its like my mate has a multimeter and i have just watched this http://www.expertvillage.com/video/1...attery-two.htm i will check the battery when i get back, then again in a few hours
Old 27-10-08, 05:10 PM   #29
hovis
Get your multimeter out & tell us the readings
i.e. After you have finished charging & then at intervals of 1 hour or 12 hours, depending on how quickly it is draining.
right is been on the optimate for4 days so
5pm today 13.31volts on the battery
Old 27-10-08, 05:15 PM   #30
Nicky S
Nicky S's Avatar
it isnt ever gonig to charge if you dont ride. i had same problem jsut charged battery then did lik 300 miles and came back and it was fine :P
Curvy With Lots Of Bits ...
But Still More To Come
Nicky S is offline   Reply With Quote
Flat battery? appollo1 SV Talk, Tuning & Tweaking 8 19-05-08 06:05 PM
Flat battery cuffy SV Talk, Tuning & Tweaking 8 15-04-06 12:27 PM
flat battery-again! ronshaw SV Talk, Tuning & Tweaking 4 02-08-05 08:04 AM
FLAT BATTERY!! philb SV Talk, Tuning & Tweaking 5 19-05-05 10:42 AM
Flat battery leatherpatches Bikes - Talk & Issues 12 12-05-05 09:47 PM
