i had a flat battery 10 days ago - had to get the bus ! so i bought a new one . trouble is this ones gone flat too. so maybe it taint battery. any ideas would be most welcome!
Oooohh this one again, do a search for regulator rectifier, you'll find lots on the subject including a few diagnostic posts from yours truly.
I second Sid Squid's Diagnosis
It does sounds like its the regulator rectifier is not charging the battery |
I have to know, alternator VS regulator rectifier?! I suppose i should google it.
Either what they said or you're going one past steering lock and leaving your parking light on ![]() |
I had the same problem...
Bought a second hand reg\rec from a written off SV (cost me R700 cause new ones were R1500) and all my problems are solved.. |
Flat battery? | appollo1 | SV Talk, Tuning & Tweaking | 8 | 19-05-08 06:05 PM |
Help! Flat battery.. | Prawn | Bikes - Talk & Issues | 25 | 26-11-06 10:42 AM |
Flat battery | cuffy | SV Talk, Tuning & Tweaking | 8 | 15-04-06 12:27 PM |
FLAT BATTERY!! | philb | SV Talk, Tuning & Tweaking | 5 | 19-05-05 10:42 AM |
Flat battery | leatherpatches | Bikes - Talk & Issues | 12 | 12-05-05 09:47 PM |
