Old 26-10-08, 12:12 PM   #21
Blue_SV650S
Default Re: Today I did go play with my RC plane ..
Set prop so it's horizontal when against compression, take wheels off altogether. That makes landing in long grass really easy.
I am not going to hand launch that big boy!! ... Also I want to put the camera on the bottom this time!!
I got a small plane that has no undercarriage (or rudder) ... could use that one ... but I think the weight might be more of an issue and again, I intend to put the camera on the bottom ...
Old 26-10-08, 12:17 PM   #22
Why not? Just put it on left shoulder, push throttle open and let it fly out of your hand.
Old 26-10-08, 12:24 PM   #23
Blue_SV650S
Coz I need the rudder, elevator AND aileron to get it airborne .. the place I was flying had some pretty big bushes/trees either side, so it has to be a rapid takeoff and landing ...
If it wasn't so gusty, I think I could have 'stall landed' it better ... but I was running out of runway and down was better then it catching some air/gust and lofting into the trees
I might get some much larger diameter wheels ... that'd help too ...
Old 26-10-08, 12:35 PM   #24
In that case perhaps take a lawnmower with you
Old 26-10-08, 12:37 PM   #25
Blue_SV650S
That is an idea ... I could hold it in my hand, run up and down a few times using the prop as a strimmer!!!
Well done that man (US Plane Crash) plowsie Idle Banter 15 16-01-09 03:46 PM
look what arrived from play.com today... Paul the 6th Idle Banter 19 01-01-09 11:10 PM
We went out to play today! Beaniebike SV Ecosse 10 11-09-07 04:38 PM
Bike v Car v Plane Jdubya Idle Banter 3 04-12-06 03:54 PM
Think you can play the guitar? can you play it like this? PsychoCannon Idle Banter 3 07-10-06 01:57 PM
