Old 02-11-08, 10:52 AM   #21
Dangerous Dave
Default Re: Front cog nut! Arrr!
We managed mine with just fat mate on bike, 1st gear, break on, and longish breaker bar. It still took a lot of trying though!
Yeap, that is the mans way! A piece of wood is needed for the weaker mechanics...
Old 02-11-08, 12:42 PM   #22
pencil shavings
Originally Posted by Dangerous Dave View Post
Nothing different on the K3, I would guess it could be the fact the sprocket has been there for 5 years!
By differance I ment the aplication of red loctite, as that it what was holding mine on.
I guess we will see when Cam_73 finally get it off if it has red loctite on it too.
Old 02-11-08, 12:44 PM   #23
Dangerous Dave
Comes with loctite from the factory, whether you use it afterwards is a personal/mechanics preference, which makes it no different to every other SV.
Old 02-11-08, 12:48 PM   #24
I use loctite, and a big cracking bar to get them off again.
Old 02-11-08, 01:00 PM   #25
pencil shavings
ah right now I know!
I didnt put any on mine when I put on the new one, should i have?
Old 02-11-08, 01:04 PM   #26
Lissa
Just Ballast
Lissa's Avatar
The woman's way is the impact driver...............why make things harder than they need be
Just don't do as I did, girls, and lean your boob against the driver..............it bruises soft bits
Old 02-11-08, 01:07 PM   #27
Dangerous Dave
Like I said, its a personal preference and i don't on my own bikes.
Old 02-11-08, 02:06 PM   #28
I use loctite because I couldn't be rsed getting a new nut. But then again I couldn't be rsed putting the front cover on either, so can very easily check if it's backed off at all.
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) leegriffiths128 Stuff Wanted 0 23-07-08 09:11 PM
Front Discs (pair) for sv650 '99 curvy + Front wheel mikeSV Stuff Wanted 1 28-05-08 04:21 PM
Front Discs, For those with GSXR Front Ends on thier SV's Ter For Sale - SV's and SV related items 2 14-03-07 12:56 PM
SV650s 2000 model, yellow. I need front central and front right fairing. OdySV Stuff Wanted 0 25-02-07 04:47 PM
K3 radiator(any condition), front header pipe, FRONT END!!!! buttmunch Stuff Wanted 1 10-04-06 10:09 PM
