Old 17-05-09, 01:17 PM   #21
Default Re: Problem removing oil filter.
Manual also says to lubricate caliper pistons with brake fluid
Old 17-05-09, 01:52 PM   #22
parkinmj
Oil filter removal tools are a waste of time all you need is a strong flat head screw driver and a hammer.
Drive it through smack it take it out repeat. once loose spin the filter off by hand ( use a cloth there will be oil everywhere and sharp pieces of metal). just becareful not to hit the thread but in the middle.
then to put the new one on i just do what everyone else does.
all the best
MJP
Old 17-05-09, 01:57 PM   #23
So tool on, spin it with ratchet is not worth it compared to getting a sweat on, getting oil everywhere and probably cutting yourself on the demolished filter?
I'll keep the tool cheers.
Also I've removed some filters fitted by dealers, it seems with an impact gun, where the filter was on so tight a screwdriver was just making a slot instead of moving the filter!
Oh Dear Oh Dear...The problem with fitting a BMC Filter and rejetting is............. Dappa D SV Talk, Tuning & Tweaking 36 15-09-08 05:24 PM
Battery problem / Alternator problem? localhost SV Talk, Tuning & Tweaking 4 07-07-06 09:32 AM
oil, filter and air filter change doe SV Talk, Tuning & Tweaking 10 17-04-06 01:29 PM
Removing the trunk from the air filter bikerskez SV Talk, Tuning & Tweaking 8 31-01-05 07:54 PM
To filter or not to Filter.....are you feeling lucky? Magoo Bikes - Talk & Issues 40 02-12-04 05:17 PM
