Old 31-01-05, 09:23 AM   #1
bikerskez
Default Removing the trunk from the air filter
Hello all, I read on here about removing the trunk from the front end of the air filter box, i have and the noise is so much louder, it's as if i can hear the cylinders fighting right under my head, MY question, Why is it so much louder and are there any other side effects from taking it off?
Old 31-01-05, 09:58 AM   #2
Default Re: Removing the trunk from the air filter
Originally Posted by bikerskez
Why is it so much louder?
Because you've removed the silencer from it, that's what the 'snorkel', as it's commonly referred to, is.
And are there any other side effects from taking it off?
On an otherwise standard bike, not significant ones, no.
Old 31-01-05, 10:13 AM   #3
Flamin_Squirrel
It also allows water to get into the airbox in heavy rain, doesnt it?
Old 31-01-05, 10:25 AM   #4
Mr Toad
I did the same, however I jacked the tank up by half an inch to get a bit more airflow, and that really allows the induction noise out
Check out Chewy's stuff
http://www.chewys-stuff.co.uk/tank_s...nk_spacers.htm
I found that the bike would occasionally 'cough' or 'burp' when closing the throttle rapidly, like you do around town, especially when the revs were a bit high (say 8k+). Whilst some of these could be amusing, some were quite violent, so you need to be a bit careful
The 'snorkle' from the SV1000 is twice the size as the SV650, ie. 4 channels as opposed to 2, so I've put one of these in for winter - I was concerned that with the tank raised & the snorkle out, the air filter is exposed to rain/water/crap, and might give rise to trouble.
I found a dog end sitting on the filter at one stage , although in hindsight I'm not sure if it was sucked in, or carefully placed there by some joker in Frith Street
You shouldn't need to get the ignition re-mapped, but it's probably worth doing so if you've got other additions like end cans, etc
I'm going to do this when the weather gets a bit better
Old 31-01-05, 10:32 AM   #5
will
Is this, in your opinion, as a result of the tank spacer, or the SV1000 snorkel? I would like more induction noise, but am not keen on the side effects you describe above!
Will
Old 31-01-05, 10:41 AM   #6
Mr Toad
It's not the 1000 snorkle - it's pretty much behaved itself since this was put in
It only coughed with it out, and the tank raised.
The snorkle(s) are rubber, and they're push fit, so you can easily pop it out, go for a spin, and then put it back in if you don't like it.
Tank is easy to remove/raise. Undo the 2 bolts, and simply lift as the tank is hinged, then use the tank prop that should be under the pillion seat to hold it up.
Old 31-01-05, 04:36 PM   #7
I found a dog end sitting on the filter at one stage, although in hindsight I'm not sure if it was sucked in, or carefully placed there by some joker in Frith Street
What! Surely you don't know anyone who would do anything like that do you?
Old 31-01-05, 07:13 PM   #8
Mr Toad
Several
Old 31-01-05, 07:54 PM   #9
Barty_b0y
you mean people ride bikes in rain ??????
OMG
Problem removing oil filter. mackrilld SV Talk, Tuning & Tweaking 22 17-05-09 01:57 PM
Removing bolts pben47 SV Talk, Tuning & Tweaking 13 30-07-08 04:16 PM
Removing the Baffles Lafgr8 SV Talk, Tuning & Tweaking 21 17-07-08 08:45 PM
oil, filter and air filter change doe SV Talk, Tuning & Tweaking 10 17-04-06 01:29 PM
To filter or not to Filter.....are you feeling lucky? Magoo Bikes - Talk & Issues 40 02-12-04 05:17 PM
