#21 |
Will check all of this tomorrow after my 10 hour round trip to Wigan to pick up my track bike.
Cheers for all your input peeps, I'll keep you updated. Regards |
#22 |
Well, I finally got around to checking the bike over. I charged it on the optimate (optimate says the battery's fine), push starter and get only a click. I jumped out the starter and get a strange wiring noise but the starter isn't trying to start the bike.
Does this mean I've fubar'd the starter by dismantling it anbd that the solenoid was the original culprit for the breakdown?? Any ideas? Regards |
#23 |
Sounds the same as the SR. Have to give that a gentle knock with a hammer and she fires. Let me know how you get on.
#24 |
Couple of things spring to mind, quality and durability are somewhat lower generally on these machines, so componant failure isn't uncommon.
How old is it ? standard check list; battery/ you say is fine solenoid/ makes a clicking noise startermotor given a direct feed from + on battery/ does it turn ? remove starter from bike, from a battery - (earth the outer casing) & + the terminal on top/ does it turn ? I'll make a presumtion here it's probably a clone of a denso one, so on the startermotor (removed from the bike) two bolts will run the length of it (internally) undo these, take off the end cap, then you'll be able to extract the central part (armature), looking down the inside of the casing you'll see a round or half round small circuit board with the brushes attached, you should be able to seperate the main body from the other end cap with the circuit board in now, three things to check here 1. check the brushes are in good condition, 2. the contacts at the base of the armature are also good, 3. the electrical contact from the outside terminal(+ postive) is isolated from the body of the startermotor (undo the 10mm nut on the outside terminal, the bolt bit should go threw an isolator of some kind, either rubber or plastic, stopping it touching the main body (which is obviously the - (earth)), and to a wire or braid which in turn leads to the circuit board, if either the isolator or wire/braid is broken it won't work, it's possible to re solder the wire/braid, and should it be the isolator a piece of innertube rubber cut to shape will do the job. HTH Edit: found this which might help. Cheers Mark.
Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming, 'Wow! What a Ride! Last edited by rictus01; 08-04-09 at 10:08 AM. |
#25 | |
turning was to give it a knock. My mechanic provided me with a strange device ![]() spring. Every time I left work I had to ask someone to poke the starter with this weight while I was turning the ignition key. |
#26 |
Cheers all.
As mentioned, the starter has been stripped and check and looks mint inside (took me ten mins to strip and 2 hours to put back together again!), the solenoid clicks but doesn't make the starter whir, if you short the solenoid the starter whirs but doesn't turn the engine over. This doesn't seem to narrow it down for me! Either the battery deasn't have enough power, despite the optimate telling me otherwise, the solenoid has given up, the starter is fubar'd or a combination of the above. Will have to investigate further tomorrow. Regards |
#27 |
please post pics off your bike btbh some are worth just putting in the tip .
#28 |
It's an 06 plate and it's in very good nick with only 2200km on the clock!
#29 |
#30 |
My brother once reassambled a starter motor backwards.... so it spun the wrong way & just whizzed round....
Non starter - injection problem? | jazazello | SV Talk, Tuning & Tweaking | 6 | 02-05-09 07:47 PM |
Starter motor Problem | Cam_73 | SV Ecosse | 3 | 28-04-08 09:06 AM |
Leccy/starter problem | goof | SV Talk, Tuning & Tweaking | 3 | 20-02-07 07:35 PM |
Starter Problem | Davido | SV Talk, Tuning & Tweaking | 10 | 17-11-06 11:34 AM |
Starter problem | Anonymous | SV Talk, Tuning & Tweaking | 10 | 30-06-05 07:48 AM |
