Old 20-02-07, 05:18 PM   #1
goof
Default Leccy/starter problem
Never had any electric problems before so was wondering if someone could help - I stopped off at the shops earlier and had had the bike running fine for a couple of short runs today. However, when I got out of the shops I couldn't get it started again, there was just a light, rapid clicking from the bike and at the same time the rev counter would flicker up, but no bite from the starter.
Can anyone help out? I remember reading about something similar but can't remember what it was in relation to!
Old 20-02-07, 05:41 PM   #2
jambo
jambo's Avatar
Default Re: Leccy/starter problem
The rapid clicking is the starter motor relay this happens for a couple of main reasons:
1) The Battery is too low on charge to turn the engine (It takes about 10 miles to recharge from a cold start so enough short runs can leave you short)
2) The connectors to the battery, starter motor relay, or starter motor are loose
HTH
Jambo
Old 20-02-07, 07:15 PM   #3
ASM-Forever
Sounds like a 1 from jambo's list to me
A good charge and hopefully it will be fine. An optimate charger could be useful to ensure the battery is topped up continuously.
Old 20-02-07, 07:35 PM   #4
goof
Thanks for the replies - yeah, that's probably it then, lights and heated grips straight on into the bargain won't have helped!
Starter motor Problem Cam_73 SV Ecosse 3 28-04-08 09:06 AM
93 zzr600 leccy problem fat_brstd Bikes - Talk & Issues 5 26-11-07 09:35 PM
Starter Problem Davido SV Talk, Tuning & Tweaking 10 17-11-06 11:34 AM
non starter problem found madmal SV Talk, Tuning & Tweaking 7 24-01-06 08:56 PM
Starter problem Anonymous SV Talk, Tuning & Tweaking 10 30-06-05 07:48 AM
