hi folks, just puttin this on in case anyone has similar problem. short while back had a problem with bike reluctant to start. cleaned ignition swith totally and hey presto for a short while. out on a jaunt at weekend and stopped for brew. pressed starter to go. nothing. 4-5 presses of switch and fires up. got home n looked at clutch switch. aha me thinks. very fine film of crud on connections. cleaned and hey presto...job done. clutch switch is non adjustable so will make sure i clean regularly. have never used electrical spray (contact cleaner), would this help
Where the hell am I?
Give em a rub with a bit of fine sandpaper wraped around a matchstick or something similar to get into the small space. Shniny contacts = good!
I've disabled mine cos i have those wrap around heated grips and the lever dont get close enough to contact with them on. But i did have to clean mine out too. it was full of foul stuff. Only thing is i have to be extra sure its in neutral before i start it but i'm still in the habit of holding the clutch in when i start it anyway. ![]()
. "Computers are great! Not for communicating tho. They have one fundamental flaw ... they don't have eyebrows." AlpineCarStereo: you win ....... eeerrr ..... ummm ..... my undying support of you, the greatest Mod this forum has ever known. My Leige. davepreston: ![]() |
Knob faced knobster
ditto i had the same problem, gave it all a good clean up and hey presto it was sorted
2001 SV650 in shimmerin green, Not broken anymore |
Whereas I threw mine in the bin.
#5 | |
Knob faced knobster
don't know how much a suzuki switch is but you could get a press to make switch from maplin and use that insted they are really cheap
#7 | ||
#8 | ||
If you remove the whole switch- ie don't just short the connector, but lose the switch assembly itself- the clutch is also a little lighter, which is nice.
Non starter - injection problem? | jazazello | SV Talk, Tuning & Tweaking | 6 | 02-05-09 07:47 PM |
Starter motor Problem | Cam_73 | SV Ecosse | 3 | 28-04-08 09:06 AM |
Leccy/starter problem | goof | SV Talk, Tuning & Tweaking | 3 | 20-02-07 07:35 PM |
Starter Problem | Davido | SV Talk, Tuning & Tweaking | 10 | 17-11-06 11:34 AM |
Starter problem | Anonymous | SV Talk, Tuning & Tweaking | 10 | 30-06-05 07:48 AM |
