#21 |
Maybe 5mm of preload. Remember that the more you use, the harder it is to get the cap back on.
It's still a big bodge, just fit some proper springs! (or some forks that work properly)
#22 |
My forks work, I've got hagon progressives fitted but just read about them not being effective without a bit of preload adjustment. So figured a few pence might improve the suspension. I've got some spare caps of some old forks could just shim them up to somewhere near 5mil.
#23 |
Have you actually measured sag or travel used by braking?
#24 |
nah lol
Is that what the cable tie trick is?
#25 |
Yeap, go forth and try it when you've got some working brakes.
#26 | |
#27 |
Yes, that's a good way to measure total travel
#28 |
cheers
#29 |
Yeah fit them there, take the fork tops off with bike supported and see how close to the yoke the seal ends up at fully bottomed out. Reassemble. Fit cable tie.
Go and brake hard on a smooth ish road, you want to have 10mm of travel remaining under hard braking on smooth surface.
#30 |
ta chris
couple of questions though how do I completely bottom out the forks can it be done by just getting someone to sit on the front end?? And do I brake front only or both?
What does Handling mean? | Stu | Bikes - Talk & Issues | 22 | 17-01-09 10:49 PM |
Handling. | Lozzo | SV Talk, Tuning & Tweaking | 62 | 02-09-07 05:41 PM |
sv handling | mic-hull | SV Talk, Tuning & Tweaking | 8 | 29-06-07 09:26 AM |
GSXR 600 K1 Handling - Anyone help ? | mattyL | Bikes - Talk & Issues | 9 | 22-05-07 08:38 PM |
sv650s better handling on k5 | Welsh Wonder | SV Talk, Tuning & Tweaking | 1 | 03-09-05 06:42 AM |
