Old 28-03-09, 07:30 PM   #21
tinpants
Ubique
tinpants's Avatar
Default Re: Dell Issue
Um, having read thru this thread I've realised that none of my stuff is backed up on my PC. All my business accounts and invoices, estimates etc and all my personal 5hit.
Errm, how do you back it all up? I'm not the most computer literate person in the world so the "kiss" method would be appreciated.
Ta muchly..........
Jesus loves you. Everyone else thinks you're a pillock
tinpants is offline   Reply With Quote
Old 28-03-09, 07:33 PM   #22
Dave20046
Dave20046's Avatar
Originally Posted by Kate Moss View Post
Laptop wont start up - says hard drive is not there
error message 0141
what to do?
It's the pink one if that helps!!
hardrive dead
Old 28-03-09, 07:39 PM   #23
_drummer_
Bellerophon, if I were you I'd get an external hard drive & copy all your stuff onto it.
I'd also back up using dvds/cds (use makes like Verbatim or Taiyo Yuden), make a couple of copies of the same files.
If you dont have any burning software I'd recommend ImgBurn ( I don't know what OS you run), it's free.
Old 28-03-09, 09:12 PM   #24
i got a dell issue lappy is just running really slow ive took 10 - 20 gig of crap off it, run disk clean up and de fragged it but its still very slow any ideas?
Old 28-03-09, 09:35 PM   #25
JohnMcL7
Ta muchly..........
Roughly how much data are you looking to back up? As drummer above has mentioned there's a couple of different ways to back up which I agree with, I'd go for a so called 'portable' external hard drive which is basically a laptop drive in a USB case. They're small, light and can be powered entirely off USB making them very convenient although if you're a desktop PC and less bothered about portability then desktop drives while bigger and requiring their own power are cheaper for the same capacity. Some examples of portable drives:
http://www.ebuyer.com/cat/Hard-Drive...ortable-Drives
In terms of software there's a couple I'd recommend, the first is Microsoft's free Synctoy - you simply tell it which folder you want to back up, which one you want to back up to and how you want the action to work (I just go for copying data from one to the other). Once you've created your folder pair you can simply hit 'run' at any time and the software looks at the two folder locations, works out what has changed or been added then updates your backup. As all the software is simply kept in a standard file structure it can be read by any system as normal.
The other software I'd recommend is what's known as imaging software which takes a snapshot of your entire drive. This means if you took an image today and your drive failed tomorrow, you could just buy another one, run a restore and you'd be exactly where you were. My choice of imaging software is Acronis as I find it's pretty user friendly and works well, you can choose to take differential images so rather than going through the time consuming process of imaging the entire drive you basically just add what's changed to the image which is much quicker. This is not quite as simple to use but the advantage is that you're getting a back up of everything which you can quickly restore to which is definitely worth looking into.
John
Old 28-03-09, 09:56 PM   #26
Baph
Phil, can you take a photo of the label on the drive and upload to the .Org? I'll type out a detailed answer as to how to swap over the PCB if you/kate are really desperate for the pictures!!
Kate, moral of the story, backup backup backup!! Then this stress is avoided.
Ta muchly..........
Tesco Online are currently doing a 1TB external drive for £70. It's stupid not to get one. Then manually copy all your sensitive data over whenever you need to. That'll get you started, and post back if you need an automated solution.
Old 28-03-09, 10:02 PM   #27
JohnMcL7
It's worth checking instore as well, I noticed my local Tescos had restocked them and they're decent drives.
John
Old 02-04-09, 12:18 PM   #28
phil24_7
They send me a Hitachi 250gb replacement for the Toshiba 160gb hard drive I had!
Result in one way but means I can't swap the boards around.
How likely do you think it is, that I will be able to get away with sending a different knackered hard drive back to them? (or none at all!)
Regards
Phil
Old 02-04-09, 12:23 PM   #29
Baph
Have they said that it has to be sent back recorded delivery etc?
I'd be tempted to tell them "Its in the post."
Old 02-04-09, 12:41 PM   #30
phil24_7
They get a courier to pick it up, however it seems with all their departments, they don't really know what is going on. When originall raised, they said to hold on to the drive for 5 days to recover the required info. The next call from dell said to return it with the courier, as did the subsequent 4 calls from dell and their courier. I keep telling them I'm keeping it for a bit and they say ok.
I will apparently get a call within 5 working days, at which time I MAY say that it was sent back with the original courier to see what happens!
If this all goes tit's up then I shall return the hard drive from my prehistoric laptop that is in the attic, it still works but I doubt I'll ever use it again as the screen backlight flashes!
Dell gettin2dizzy Idle Banter 12 09-03-09 09:56 AM
Don't buy a Dell Inspiron! Berlin Idle Banter 20 17-12-08 09:02 AM
What's that song on the new dell advert? DarrenSV650S Idle Banter 2 27-11-07 12:12 AM
DELL PC's not so bad... skint Idle Banter 16 13-05-07 04:20 PM
Anyone bought a computer from Dell? A-jay Idle Banter 13 07-06-06 03:10 PM
